CT5-V .
5VBW Nick
US of A
'24 CT5-V Blackwing
I don't know much about cars but that doesn't sound like lifters or fuel injectors.
Strange that it seems to be only the manual engines having issues, I know they’re built with different components, but I have yet to hear an automatic going down?
Sounds like a rod knocking, due to spun bearing failure. Take it to the dealer.
Damn I hope not. Going out to start it now for a listen.
Just took it for a 10 minute drive and it's gone (for now). 🤷🏻
Doesn't sound at all like a rod knock, its a ticking lifter. Rod bearing failure comes from the bottom and is a heavy metal to metal knock and sometimes isn't consistent, meaning it sometimes it isn't present at idle for instance.
Are you 100% sure the dealer used the correct oil? I usually go back to the last thing that changed and start there. I'd either learn to do the change myself or find a good independent shop that you trust for things like oil changes.
No idea, changed before purchase. Thinking it's time for a change though
If it’s rod knock there would be fluctuation in your oil pressure, I know from experience on other motors!
And since I know nothing about the V8 in the 5BW, it isn't the usual Direct injection tick is it?
