CT5-V 2025 Launch control, conditions not met
putz173
Ontario
2025 CT5-V
When entering launch control on my 2025 I get a message saying conditions not met. Everything the owners manual listed as requirements is met.
The only thing I can think of is with the weather here they tires are always cold/cool and not yet normal/warm but that’s not a listed requirement.
In PTM race 2 and traction/stability shows disabled as it should for launch control.
Do you have over 500 miles on the car?
Ok. I don’t think the system cares about tire temp so it must be something else.
By the way, race 2 does not completely remove all tc and sc. However it removes the most out of all the PTM settings. The lights come on, as I have learned, because it is a law that the lights must come on if tc or sc is reduced to anything other than 100% on.
Put it in drive and no change, maybe the launch control needs more KM than the standard breakin 🤷‍♂️
assuming the break in period is preventing it, not quite the same as where it raises redline I guess
Caution
Follow these recommended guidelines
during the first 2 414 km (1,500 mi) of
driving this vehicle. Parts have a break-in
period and performance will be better in the
long run.
• Avoid full throttle starts and
abrupt stops.
• Do not exceed 4000 engine rpm.
• Avoid driving at any one constant speed,
fast or slow.
• Do not drive above 129 km/h (80 mph).
• Avoid downshifting to brake or slow
the vehicle when the engine speed will
exceed 4000 rpm.
(Continued)
Caution (Continued)
• Do not let the engine labor. Never lug the
engine in high gear at low speeds. With
a manual transmission, shift to the next
lower gear. This rule applies at all times,
not just during the break-in period.
• Do not participate in racing events,
sport driving schools, or similar activities
during this break-in period.
• Check engine oil with every refueling
and add if necessary. Oil and fuel
consumption may be higher than
normal during the first 2 414 km
(1,500 mi).
• To break in new tires, drive at moderate
speeds and avoid hard cornering for the
first 322 km (200 mi). New tires do not
have maximum traction and may tend
to slip.
• New brake linings also need a breakin
period. Avoid making hard stops
during the first 322 km (200 mi). This is
recommended every time brake linings
are replaced.
(Continued)
I don't think it has anything to do with it, but the standard break-in is not 500 miles as noted above.
Guessing it’s the 1500 miles for that, and the redline increase is just 500 miles
I have the same issue... no launch control. Tried seatbelt, next will try a wider longer road. No dog on backseat... ?? Then it goes to the dealer for the Launch control, and the Super Cruise that isn't working either 3800 miles...
sounds like you might have a sensor issue or something stopping things from working? im assuming mine is shy of the 2400 km "breakin" in the manual and thats why
2025 BW with Precision Package LAUNCH CONTROL - Somewhat Figured it out, I think this is the or my additional checklist after you press the Launch Control Button and the options are not highlighted for use: Must be in TRACK Mode, before you put it in V-Mode. Make Sure your Seatbelt(s)are/ is on; I had my dog in the back had to fake click it (No I didn't LAUNCH with the Dog in the Back !) Steering Wheel Straight, foot on Brake, nothing in front of you, played with Traction Control Button (Held it Down until both Traction Control and Skid Control light came on (see pic attached) until and my options Finally Highlighted. You can choose AUTO or CUSTOM LAUNCH, and LINELOCK is also available to warm and wear out your tires ! P.S.- Love the Linelock prompt ! (see pic) "Release Brake. Floor it."
if you are in tack 1/2 PTM it disables all the traction for you, but i did try that too
i am just hoping i need to roll over 2400 KM past what the manual states i break in
Please try this: it also enabled my SuperCruise which wasn't working. (Like it was a glitch) press the traction control button in front of your shifter.. Hold it down for a few seconds after you toggle on and off: that was the trick for me (can't hurt to try.)
Is GM still offering 2 days at Spring Mountain for new BW purchases?? If so, I HIGHLY recommend you go as they'll show you how to use launch control, PTM modes, etc. The car has a LOT of configurable options, some of which are not obvious
