2025 CT5 BW - AKG Settings
mkr14401
Los Angeles
2025 CT5-V Blackwing
Has anyone had a chance to play around with the audio settings on the new system in the 2025s? Trying to figure out the optimal sound configuration. It seems odd to have to choose between “front” and “rear” focus and also have an adjustable surround feature. I’m not a huge fan of having the audio focused on the front of the vehicle and it feels like it’s lacking bass, but it sounds worse if switched to the rear of the vehicle. Adjusting the surround feature doesn’t seem to change much.
I always use Red Hot Chili Peppers - Behind the Sun to tune stereo systems I've built or set up.
My settings are:
  • Audio -> Sound
    • Equalizer -> +11 bass, +0 Midrange, +1 Treble, +5 Surround
      • I'll sometimes change it to +8 bass or lower for highly-produced hip hop.
    • Fade/Balance -> 4 clicks rearward
      • I think this is the secret sauce as it lets more bass come through
    • Sound Mode -> Normal
  • Settings > Apps > Audio
    • Adaptive Volume On
When I'm listening to a favorite song, I have the yellow volume bar just a few clicks past the V where it says Audio Volume. The volume needs to be up there or higher for balance to be great.
I go full surround then plus 3 on bass, midrange and only plus 1 on treble. Mine are really basic, but I’m really impressed with it. I’ve had some nice custom systems in the past also for reference.
Op, were you able to find the optimal settings ? I picked up my BW 2 days ago and so far stereo is the only thing that is really below expectations.
My settings are:
  • Audio -> Sound
That’s a pretty good rundown right there. I find Metallica’s black album to be pretty good as a tuning fork.
I’ve had aftermarket subs in every car I’ve ever owned, but don’t plan on putting anything in the BW. Granted, I only drove it for 40 minutes after taking it off the lot before dropping it off for Ceramic Pro full wrap/tint. But I figure if this beast has 16 speakers then that’s gonna sound just fine in the cab. If down the road I want to throw an Alpine shallow sub in there somewhere then so be it.
My settings are:
  • Audio -> Sound
Thank you for the details. Do you keep focus to the Front or Rear?
Hmmm. I have everything at the default settings and the audio sounds pretty good to me. Much better than the Bose 14 speaker system in my C8.
Of the three vehicles I drive regularly, a '23 5BW, '21 C8 HTC, and '21 GMC Sierra, who would have thought the Sierra with the basic audio system has the best-sounding bass of the three?
My audio didn’t sound great until I put the focus on the front, but then manually faded it slightly towards the rear of the vehicle. Before doing that, the audio was always underwhelming. I love the way it sounds now.
The fact that I have to turns the system up to at least 45% of volume range in order to hear everything makes me wonder if the setup is underpowered or if the cross-over setup is suboptimal.
That seems to be the consensus on these systems. That they need volume to sound good.
45% volume is loud as fuck and this is coming from someone that attends like 10 metal concerts a year. I don’t know how anyone can stand to drive around like that.
My settings are:
  • Audio -> Sound
This made my audio sound 100x better, thank you. The only difference I did was use +10 bass +1 midrange +2 treble. Everything else was the same.
I just got my car today, and after coming from an Audi, I was pretty disappointed in how the AKG sounded. I've heard that after about a hundred hours, the system starts to sound even better due to the break-in period.
Huh, never heard about a break-in period for the audio system. I learn something new every day (hour really)!
How do
My settings are:
  • Audio -> Sound
How do you do clicks backwards on fade/balance? Mine is a straight slider that moves. Sound Mode also has front/rear & surround settings that go from stereo to surround 2d
How do
Mine's a 2024 pre-facelift w/o wraparound instrument cluster if that matters. The important thing is if you fade rearward a little bit it makes a difference in bass and depth while leaving the soundstage toward the front more than other systems I've had.
I've also found if you move all equalizer settings up or down together the same # of clicks it doesn't change EQ much and will give you more volume knob adjustment.
Keeping an eye on this thread. Like xnifex, I have a 2025 and curious to the best sound setting.
I had a 2022 CTS5V and the stereo sucked
I have a 2024 CTS5V and that thing Booms, best sound system from factory I have ever Had, and I have had a bunch of trucks and cars
