Here's the article I saw on line about "chips". One thing I won't do is jeopardize my 4BWs warranty. It's certainly fast but any major repairs are likely to be costly.
Chip Your Car & Save!
- Increase Car Mileage
- Boost Horsepower
- Increase Torque
- Improve Throttle Response
- Cutting-Edge Technology
- Install in Less Than 60 Seconds
Cadillac Performance Chips
$76.49 – $175.94
Cadillac Performance Chips are an industry leader for improving Cadillac performance and MPG.
View attachment 22724Cadillac Chips are best in class horsepower, torque and fuel economy gains. A 60 second plug-n-play install is all it takes to increase the performance and mileage of your vehicle. Performance is improved by dyno tuning your Cadillac, creating a more efficient fuel map changing air/fuel mixtures. The tuning improves the timing and boost pressure (if your engine applies), all while maintaining the vehicle warranty. The performance chip easily unplugs for emission testing and diagnostic work.
No modifications are required for your performance chip to work on your vehicle. If you modify your vehicle in the future, the performance chip will recognize the modifications, adapt and correct the air/fuel mixtures. If you ever wish to return to your vehicle to stock form, simply unplug the performance chip from the OBD2 port, and the factory ECU will resume with the original fuel map.
Keep an eye out for vehicle performance products offering impossible numbers with just a resistor. Chip Your Car Performance Chips are the genuine tuning solution.
100% GUARANTEED RESULTS,
or your money back!
SHOP NOW: Cadillac Performance Chip Products
| YEAR | Choose an option19961997199819992000200120022003200420052006200720082009201020112012201320142015201620172018201920202021202220232024 |
| MAKE | Choose an optionCadillac |
| MODEL | Choose an optionAllanteATSBroughamCateraCimarronCT4-VCT5CT5VCT6CTSCTS-VDeVilleDTSEldoradoELREscaladeFleetwoodMark VIII LSCSevilleSRXSTSSTS-VSTXXLRXT4XT5XT6XTS |
| CYLINDER | Choose an option4 Cylinder - Turbo6 Cylinder Turbo4-Cylinder6-Cylinder8-Cylinder |
| GRADE | Choose an optionSTANDARD (20hp, 1 mpg gain)MID-GRADE (40hp 3 mpg gain)PREMIUM (up to 60hp 5mpg gain)Clear |
Add to cart
SKU: N/A Category:
Cadillac Tags:
cadillac,
cadillac performance chip,
car tuner,
ECU Tuning,
performance chip
Description
Cadillac Performance Tuning
