Thank you sir I get that but even the C8’s RPM’s are limited but with in the available RPM range engine up/tq are reduced until 500 miles.
And scares the shit out of you as the HUD starts flashing likes it going to explode!On a manual, the display shows red above 4500, but there is no computer control on it... you have to be diligent to shift in time.
Interesting discovery...I think I may "accidentally" test the permissiveness of the manual 4,500 limit...
Technically that should be "you should not go over 4500" rpms. This is a soft limiter and you can in fact go beyond 4500 rpmYou can't go over 4500's
I understand but just to be devils advocate, if break in is 1,500 miles why should our tach change to 6,500 rpm’s at 500 miles? What message are they sending when the training wheels are taken off at 500 miles?Also, the break-in is 1500 miles...if you believe the owner's manual.
Sometimes they dumb things down so people don't get frustrated. Good example: My 2001 M5 was the first car with the super cool (at the time) variable redline that started at 4k rpm when cold and gradually opened up to the 7k redline as the engine got warm. Trouble is, they linked it to water temp rather than oil temp, and once the full 7k was indicated, the oil temp was only a little off the "cold" peg. I always waited until oil temp was closer to operating.I understand but just to be devils advocate, if break in is 1,500 miles why should our tach change to 6,500 rpm’s at 500 miles? What message are they sending when the training wheels are taken off at 500 miles?
That's not entirely true, since the manual specifically mentions different intervals for brakes, tires... Actually, there is no mention of 500 miles in the manual-only 1500 and to keep it under 4000 RPM for that time. The tach redline seems to be a reminder to take it easy and there is no limiting function of RPM. C8s have a power limiting function, but I know of none for the Caddy.I believe that smarter people than me have mentioned that 500mi for normal spirited driving, but 1500 for track is recommended. (I know the manual just says 1500)
... and that it is more about brakes, tires, differentials, etc... than engine
