Laser jammer installation
speedy
nj
2022 Cadillac Ct5-V Blackwing
So I installed an al priority laser jammer. I'd like to install rear heads and I was wondering if anyone has removed the trunk applique. I will be posting pics of the front installation so you guys can see how I did it. So after removing the trunk liner. I noticed a few bolts in the trunk and even after removing them it wasn't loose enough.
Glad someone finally did this mod. Been pondering about the ALP front sensor installation location for some time.
Do you have a 4BW or 5?
Make sense that you need a laser jammer given your forum handle.:)
I have a 5. Also, I do like the occasional pull in Mexico. :cool:
Would love to see the front end pics. I have an appointment this Friday to have the Stinger system installed and would really have chosen the ALP for better performance, but couldn't figure out a good way to mount the front heads.
This is what I have so far. I don't like the how the tx sensors are mounted so I'm gonna make custom brackets for them. I'll post when they are done.
Is it possible to mount these behind the grill or is that too much of an obstruction?
You arent supposed to thats why for now im gonna leave the tx sensors like that until i can make custom brackets for it.
@sp
Reviving this thread as I'm about to do a similar install. I was wondering if you made any further modification/mounts and any advise? I'm most likely going to go with the 3 front sensors, no rears.
Also, have you done any testing of the system?
Thank you very helpful pics. Just got a new ct4v and I'll be installing a TPX system in the next couple of weeks. Does your car have Super Cruise like mine. Note SC came with the car. I didn't order it
Had some medical issue so no progress.. One thing I did do is find a good place to mount the CM head (middle one) and that is on top of the plastic GM lincense plate mount. Nice and sturdy. The Cadiillac CT4 grill is a bad place for easy jammer head mounting. I did experiment with Bondo putty thinking I could use it to create a mount then after it cured my friend said he could scan it and 3d print a mount. It was a bit messy but all the grill slats were masked. I'll keep trying. Anyone else ever tried this. @Atlein your are in the middle of the laser belt. Are you running countermeasures?
Sorry to hear about your health issues. I am planning on getting ALP in the Fall which has slightly larger heads.
