Same stuff my old ATS used.In my ZL1 I use the below. I would guess it would be the same for the Blackwing;
I was wondering if it was the GL-5, like the SS Sedan used. I didn't want to comment because I didn't know for sure, but if this differential needs the GL-5 then putting in the LS fluid will not be good. If the clutch packs require GL-5 and you put in the LS fluid, be ready for a one tire fire, just like what would happen in the SS.This is what goes in the 5BW
I called. Dealer did not know. They said somebody from service needs to dig into the service manual, as the car is too new and it doesn’t show under the parts list. They had several options which 2 of them listed above. Didn’t know which one is the correct item.This is interesting. Have you called the dealer to ask them?
It's a Torx? On the 'vette and Camaro, it's just the 1/2" end.Went to change my diff fluid in preparation for Road America in a couple weeks....what size Torx did you use for the drain/fill plugs? Got under the car expecting it to be the same as my 6 gen camaro and realized I didn't have the right tools lol
Damn, that's a pretty reasonable expectation.Went to change my diff fluid in preparation for Road America in a couple weeks....what size Torx did you use for the drain/fill plugs? Got under the car expecting it to be the same as my 6 gen camaro and realized I didn't have the right tools lol
