CT5-V CT5-V BW/Camaro Same Suspension?
poor-sha
NoVA
I was at the track last weekend talking to bunch of Camaro guys about the Blackwing. Everyone recommended using the SPL upper control arms and eccentric lockout kit because the Camaros are notorious for the alignment shifting on track. It doesn't appear that SPL lists anything specifically for the BW but does anyone know if the upper control arms and the toe links are the same between the 5BW and gen 6 Camaro?
While there may be a few parts in common, I would suspect the layout, geometry and components to be VERY different.
6th Gen Camaro is Alpha, not Alpha 2, Wheelbase is different, and BW has MRC4 vs older version for Camaro.
I noticed that while the TR-6060 is the same unit, the rear diff looks completely different than the 1LE/ZL1 diff.
I've owned a SS 1LE for 5 years and track 9-12 times per year. The only time I can confirm needing a alignment is after Sebring weekends. And everybody needs an alignment after Sebring. :D
