Wscott002
- Joined
- Apr 17, 2025
- Messages
- 11
- Location
- Jacksonville, FL.
- V-Series Cadillac(s)?
- 2024 CT5 V Blackwing
Make sure you check all four springs, if they left it in one, they may have left it in the others. It is strange that they would not have taken them out when they did the pre-delivery inspection upon the vehicle's original delivery.Good Morning, I’m getting an alignment this morning and saw this red block in the front coil springs, should it be there ? Thanks
Yes, it should feel softer when cruising and you will have better handling as well, now that it can lower like it needs to with the springs and not handicap the Magnetic Ride Control. I am curious what you will think of the handling went you are driving it to the limit.They were just in the front springs, I brought it new early last year, drove it home from S. Florida, just over 7k on it now, they must have been in there since I got it. The ride doesn’t seem much different maybe a little softer ? Thanks for the info.
Do you know if they are always in all 4 or if sometimes it’s front only? My dealer left 2 in the trunk when I picked up my car. Should I check for 2 more?Make sure you check all four springs, if they left it in one, they may have left it in the others.
Misleading image. I want a coupe Blackwing.
