2025 CT5 BW - AKG Settings
I found the solution.
Add an aftermarket subwoofer in the trunk. 😂😎
I just picked my car up from the Mo Music in Reno and just the one sub made a huge difference. (He was able to replace the “spare tire” foam insert and flooring cover with a custom floor box set up that didn’t require any drilling of any kind. It just fits perfectly into the space. Both the sub and amp were easy to fit in all of the space that foam insert takes up.)
The AKG system is simply a bit underpowered, and 6x9 speakers aren’t going to hit those low bass notes as cleanly anyhow.
I have my bass at +2 mid at +4 and treble at +3 I moved the focus trajectory so that the plus sign is basically on the center of the floor of the backseat. I can use the bass knob to raise or lower the sub power/bass.
The sound in the car is absolutely beautiful. As a bit of an audiophile I can say it sounds realllllllly clean.
I’ll post pictures in a bit, then again after I go back to Mo for the re-tune and he’s installing a light to shine on the speaker set up (he did the speaker baffle in carbon fiber to match the carbon fiber of the speaker cone.).
He also made me a little shelf for my spare tire (from Modern Spare) since the ‘25 CT5-V BW doesn’t have a man actual location for a spare.
So you added a sub (with amplifier), and kept the 6x9s on the back shelf?
I’m not an audiophile … but my impression is that the sound in the CT5-V Blackwing is “thin”. It sounds ok, but it doesn’t seem to have any depth or presence. Even with talk radio! Any idea of what I’m picking up on? I think the sound in my old 2014 Ford Fusion was better, and it was just the stock audio system.
Lol i also have a 2014 fusion & loved the stock audio, but a sub took it 3 notches up. I've since had to replace all the speakers, but it still sounds so good. Tempted to put a sub in the ct5v
It looks like no one has found a sweet spot for the sound settings (sans sub) for a 2025+
My guess is that because the Caddy has 16 speakers, that they’re all pretty small except for the 6x9s. So the amplifier used to push them is likely not very powerful.
The reason many people have found that fading the sound slightly to the rear of the car sounds better is probably because it pushes more power to the 6x9 speakers.
Personally I think that the 3D sound all the way up sounds best, and the volume at 40% or above was needed for the stock system to sound okay. Like mentioned by others, I had the aiming sight of the fade centered right behind the center console, and it did make a difference.
I am interested to see if there’s anything to the whole break in period someone mentioned. I know speakers definitely do need to be broken in, but I’ve never heard of it being as long as mentioned.
I do have to say that adding the subwoofer made the system sound incredible honestly.
Got a picture of your settings?
What's the easiest way to add a small sub? Anyone have a writeup or a materials list?
there is a thread where a guy shows step by step how he built an enclosure for a subwoofer for that extra space on the rear side of the trunk, and another where a guy shows how he built one replacing the floor of the trunk (similar to mine).
How easy any of it is depends on your expertise level. I’ve always added my own after market speakers myself up until this car. There’s so much technology in this thing, so I didn’t want to mess with anything and thought it best to bring it to a professional. Oakland call center movie
This is with the sub added mind you. Without, I had the bass turned up higher.
Anyone discover a suitable setting for 2025+ with stock speakers?
On my 2025 CT5-V BW, I found that setting the system to "Rear" a makes a significant difference in bass response. You can then fade the speakers more front-ward to get the treble/mid more driver focused. I also increased the 2D surround to the maximum, which seems to open the sound stage a bit more without much detriment to the sound quality.
The fact that I have to turns the system up to at least 45% of volume range in order to hear everything makes me wonder if the setup is underpowered or if the cross-over setup is suboptimal.
In my 2024, music plays much louder when using Amazon Music directly through Alexa "Alexa play ...." vs using Amazon Music or Spotify through Android Auto. With Android Auto, I can be close to 75% with the windows down on the highway to hear music at a reasonable loudness.
When using Alexa directly through the voice controls, I'm probably at 40% or something like this in the same situation.
The reality is these AKG systems are poor, and certainly below average compared to what other cars use. Tweak the settings or add a sub, neither delivers any kind of real audiophile performance. A sub will give you a bass heavy sound, but you're still stuck with the poor reproduction of the stock system. If that is what you want in this car, you need to replace all the stock speakers and add some proper amplifiers.
Currently renting a Chevy Blazer & i swear this stereo seems to pack way more punch than our akg system.
My ’21 GMC Sierra with the base infotainment system honestly has the best midrange and low-end of any GM vehicle I’ve owned—better than the C8 Corvette, Camaro ZL1, Blazer, CT5-V Blackwing, and even the Bose system in my Porsche.
To my ears, it’s only missing a bit of high-end clarity, but otherwise it absolutely rocks.
The akg system in the 4BW is a lot better with it having a sub already. The 5 seriously lacks sound and bass compared to the 4. I've owned both.
I've added a sub to both and the 4 wins hands down on sounding better. I'm in a 24 model with the 5 and no matter what settings I used the stock system just didn't improve for my liking. Adding a sub to the 5 helped out but it still lacks low end bass when the volume is down.
Good luck to anyone wanting to seriously improve the sound. As someone said above, you're going to have to replace everything if you want major improvement.
Its the compression being used by Android Auto and BT that affects the volume. So streaming via Alexa, Pandora, whatever uses the cars internet forgoes that compression.
I never noticed it in the past as I don't stream to my cars, used AA, but I also ripped the systems completely out and rebuilt from scratch. Since the system was so much better I never needed to turn it up to be at reasonable volume. (ie system overcame the compression issue)
I noticed in the Cadillac because I was not super happy with the audio and didn't necessarily want to rip the whole thing out since it was so complicated. I was switching between the radio, streamed by car and AA and was noticing a definite volume and soundstage difference. End result for this car I only use Pandora or Alexa streamed and have added sub and amp to the system. I no longer use AA or BT connection for audio from my phone.
