M6 cruise control "feature"
leres
USA
2025 CT5-V Blackwing
My 5BW is my 4th manual transmission car with cruise control. With all until the BW, touching the clutch pedal would disengage cruise. But I've found that the BW gives you a window to change gears without dropping out of cruise control.
At first I thought it was a good feature; now I'm not so sure. What I've experienced is approaching a red light or stop sign, I sometimes downshift and coast down and I'm finding that that cruise control will jump on the throttle and try to get back up to the set speed.
Honestly, I would turn this feature off if there was a way to.
If you just tap the brakes once, it should disengage. Then just keep coasting/down shifting
Of course. Or push the disengage cruise button on the steering wheel.
None of it helps retrain my decades long habits.
Well, I find it very useful in my 4BW for driving in mountain country when traffic keeps my speed below 65 mph. The RPM in 6th is low enough that I feel uncomfortable letting the engine lug up steep hills. A simple downshift without having pause cruise, then reactivate after downshifting makes it a lot more likely I'll do it.
