Probably Dumb Questions
While we are on the topic of "probably dumb questions"..
Is it just me (don't answer that ;) ) or is it a lot harder to get the trunk to pop/open than it needs to be? Yesterday, I parked my 5VBW in the garage, made sure the unlock button had been pressed, turned the car off, got out and went to the trunk. Could not get the trunk to open by pressing the button on the trunk. I then pressed the trunk release button on the key fob 2x. Trunk still refused to open. I then pressed the standard unlock button on the key fob 2x and pressed the trunk unlock key fob button 2x (unnecessary, I know, car was already fully unlocked), same result. I then opened the driver's door and tried to press the trunk pop button there. It would depress but not unlock the trunk.
Finally, after getting irritated, I pressed the "start button" ( I hate these things btw) and got to what appeared to be accessory/steering unlock mode (not ignition/dash lights mode or engine running mode) and the dang thing unlocked/opened.
I admit I have not delved deep into the owner's manual (partly because I would much rather have a paper manual than stare at a screen any more than I have to).
Is this normal behavior?
What I wouldn't give for a cable actuated trunk release...
I have a '22 5BW and have had this happen a couple of times during my first year of ownership. But it has not happened since then in the subsequent 3 years. It is very odd. Same resolution for me. Started the car and trunk worked again. I chalked it up to electric gremlins.
Hopefully you just have the same glitch that @jwolf99 had... But if continues go to dealer. That is not normal and not in the manual.
I have a 4bw and my trunk has had some issues before as well. It’s annoying.
For 2 - if you are constantly pressing "V" mode, I would recommend you just configure "My Mode" instead. "My Mode" can be configured in the car settings and is just as customizable as V Mode. You can switch to "My Mode" by toggling your mode selector near the stick. The "V" mode is moreso meant for either short burst shenanigans on the street or using it on the track.
Thanks for the tip! I’ll try this and makes sense.
Selecting the Alert Timing
The Collision Alert control is on the steering
wheel. Press[to set the FCA timing to
Far, Medium, or Near. The first button press
shows the current setting on the DIC.
Additional button presses will change this
setting. The chosen setting will remain until
it is changed and will affect the timing of
both the Collision Alert and the Tailgating
Alert features. The timing of both alerts will
vary based on vehicle speed. The faster the
vehicle speed, the farther away the alert will
occur. Consider traffic and weather
conditions when selecting the alert timing.
The range of selectable alert timings may
not be appropriate for all drivers and driving
conditions.
2) When I press my V-button on steering wheel, it puts the car into my preferred settings and shows it on the screen. That screen stays up until I manually hit the X in top left corner. Other screens seem to go back to what I was viewing before after some wait period. Is there a way to have the V-button screen automatically turn off without manually closing it out? I hit the V-button nearly every time I drive.
My 2024 reverts back to the previous screen.
3) Good lord is the front crash alert sensitive! Probably means I get too close to cars in front of me, but my car is constantly alerting me (HUD warning and seat vibrate) that I am about to get in a wreck (so far, no wrecks). Is this setting adjustable?
FCA can be disabled through vehicle
personalization. To view available settings
for this feature, touch the Settings icon on
the infotainment home page. Select
“Vehicle” to display the list of available
options and select “Collision/Detection
Systems”.
Haha, I thought the gap setting was for auto cruise control which I don’t have instead of the crash alert sensitivity. So the answer to #1 addresses #3. See I knew these were dumb questions 🤣
Can I add a dumb question too?
Just got a 24 5BW and the track gauge display theme doesn't work quite the same as the 4BW. Is the only RPM indicator just the raw number for RPMs instead of filling the upper "wings"?
If equipped with both it does both. :)
In track mode it'll begin filling the wings once you're in higher RPMs. Sport has a more traditional tach if needed. Similar story w/ the HUD.
Funny how such a small thing can be so irritating. Only makes it worse that this is happening on a $100k+ car. Were it a $27K Hyunkiasubishi I could _maybe_ live with it....
Thanks for the input. I will keep an eye on it. Guess it could always be worse!
I figured it out. Didn't realize there was a "tachometer" option that shows up in the track display theme. I just never knew that thing existed before.
I can never get the hands free trunk opening feature to work reliably. Maybe I'm doing the leg kick, sweep, lift wrong?
Cobra Kai Sweep GIF by IFC
Use a straight quick short thrust. No sweeping or twisting involved.
I need MyMode to keep my cranky neighbors happy. It's the only one you can put into stealth and start in it.
I also just acquired an '25 5BW manual! Loving it so far, but also had a few questions:
  1. Is there a way to turn off the audio? Other than just decreasing the volume to zero?
  2. I'm finding the door catches when I open it after pressing the rubber button/strip inside the handle. I have to press it again sometimes to get the door to open. This occurs on all of the doors. Is there a trick to open the doors smoothly? They seem to work differently than my BMW.
  3. Is there blind spot monitoring on the BWs? I was given a CT5 loaner and it had monitoring on it's mirrors, which look the same as those on the BW.
Thanks for your help!
I have a 22, so can't answer #1.
2) same issue sometimes - in my experience, we are moving from push-the-button to pull-the-door faster than the mechanism. I've just added a slight delay between clicking the button and pulling open
3) crazily enough, no BSM in 25s (though I believe it's returning for 26s)
Try pressing the hang-up button on the steering wheel. That usually mutes audio.
