ajtx00
Can you do a cold start up close? And a few revs?
I don't think the videos are doing it justice. In my opinion I think it atleast had a 30%-40% improvement in volume, and a 50%-60% improvement in sound signature.Yea, the stock exhaust does sound good. No comparison to the ATS-V. Hard to justify 3k+ for a little more sound.
Yeah, the ISF look is a deal breaker for me. If that can be corrected, it's worth the price.here is some better pictures and a link to a video on google drive of the exhaust note in sport and tour! More videos once it stops raining with a go pro comparing before and after
The tips aren't super adjustable due to the bends, this is far in as the outer tips can go, so I did that and then made the inner tips match.
20250505_180402.mp4
Small request: Can AWE or someone with the exhaust provide some videos under load? Personally i'm not interested in how it sounds revving; much more important how it sounds borh inside and outside while cruising and WOT.
Thanks - I did miss the entire video. I'd only seen shorter clips previously.Did ya miss our entire sound clip video?
Starts with an overview of what the system looks like, you can skip ahead straight to sound clips at 1:59
We make it a point to get every driving situation incliding interior, exterior, WOT, tame "in town" driving, etc.
Can you share the dyno plot?Dyno rollers with the Cadillac CT4-V Blackwing and the AWE Switchpath™ Exhaust ft. patented drone-canceling 180 Technology®
Learn more right this way..
Why? They are not claiming any power increase. There isn't any from a catback exhaust. Its just a sound clip under load. Good clip, AWE. Thank you for that.Can you share the dyno plot?
Yes they are.Why? They are not claiming any power increase. There isn't any from a catback exhaust. Its just a sound clip under load. Good clip, AWE. Thank you for that.
Ok. I stand corrected.
What makes you think that?I am assuming that is on an unlocked ecu and on the same aftermarket calibration? A stock calibration car can't make any more power with aftermarket parts.
Thanks for the info!We appreciate your interest! At AWE, we pride ourselves on being transparent and honest with regard to reporting every system's power output/gain. Releasing a system that doesn't produce measurable gains in power is against our core mandate.
We provide dyno testing numbers on nearly all product pages, located in the "Performance Specs" section. You can view the full product specs and dyno sheet here:
Product Page: CT4-V Blackwing by AWE
Dyno Sheet: CT4-V Blackwing Test 2025/04/22
If you have additional questions feel free to reach out to us—we're here to help!
Modern engines control torque output to predetermined maximum values. Changing these maximum values requires modifying calibration. So installing parts without modifying calibration only increases potential (if even that) of the car to make more power/torque, but not actually do so.What makes you think that?![]()
