Lug nut torque question
Snorlax
Canada
2025 CT4-V BW
I have some Rays Dura-Nut lug nuts that were previously on my FK8 Type R and was thinking about throwing them on the CT4 BW but the box for the lug nuts mentions a torque spec of 140N*m (~100 lb-ft). The manual for the CT4 BW has a torque spec of 140 lb-ft which seems excessively high to me, the FK8 is also M14x1.5 but had a torque spec of 94 lb-ft. Given that these lug nuts are aluminum I don't think its a good idea to go that far above the torque stated on the box and wondering if running them at 100 lb-ft will be fine. Anyone been running lower than the OEM torque spec?
Those Dura-Nut look like awful lug nuts (the supplier calls them 7075-T6 and "duralumin" which is a 2000-series aluminum--both can't be true at the same time). The torque spec is required not optional. You have to reach a certain torque to achieve preload on the stud to prevent loosening--if your chosen lug nut can't handle that torque you shouldn't be using it. High strength fasteners require higher torque to preload because they're harder to stretch. You should never use aluminum lug nuts for a myriad of reasons, most notably their lack of a fatigue limit.
If you're looking for a dressier lug nut, try McGard Spline Drive, which has a highly chip-resistant finish and a floating seat. You'll also need a P/N 65302 (22mm) or 65301 (1") spline tool--I recommend getting two, so that you can put one in the glove box and leave one at home.
You'll also need a P/N 65302 (22mm hex) or 65301 (1" hex) spline tool. I recommend getting two: put one in the glove box with a cheap Capri socket and a McGard 70007 pouch and leave one at home.
I always try to go OEM with torque specs (and parts for that matter).
My 2014 CTS-V used the same M14x1.5 lug nuts. The first time I messed with them I thought "holy s*** these are tight!" But they are also a lot bigger than the M12x1.5 lug nuts on my C6 Z06 (which are 100 lb/ft).
I would not use Aluminum lug nuts for several reasons, but mainly the much lower tensile strength. Use recommended torque spec so you don’t crash into another forum members car when your wheel comes off.
McGard and call it a day.
Contacted the manufacturer and it looks like the torque spec on the box is a general recommendation for m14 studs, they say it can be used at 140 lb-ft no problem. Despite that, many valid points on aluminum lugs not being ideal
And safety is always key so not worth risking that but learned lot about what determines the torque spec. I am now very curious what material grade GM is using for their stud that requires 140 lb-ft to get the desired stretch
It’s not that usual, my Dynatrac axles on my Jeep use 9/16 lug nuts and torque spec is 150ft*lb. In the case of the BW I would think the torque spec is in relation to high load conditions on the track.
The heaviest vehicle I've owned is a Lexus RX350 which only needed 76 ft-lb and that thing is a boat. I guess I've been stuck in the JDM world too long where aluminum lug nuts is pretty common.
I assumed the torque spec for the Type R was because of track loads making it 94, but for the same thread size just wasn't expecting 140 for the BW:LOL:
With few exceptions, all GM fasteners are Class 10.9. The torque spec is literally the textbook value rounded to the nearest 10.
Great chart.
The factory lug nuts are stamped with "190 N-M 140 FT-LBS"
I haven't taken the lugs off yet, didn't know they did that
Thanks for the info! Ask dumb questions, learn new things. Great to see data backing up why GM chose the torque value
