CT5-V Corsa cat-back exhaust installation tips & pointers, along with my thoughts/review (short video included)
5VBW Nick
US of A
'24 CT5-V Blackwing
Well, I finally had the time and weather to install my Corsa cat-back exhaust this past weekend, and I wanted to share some info I feel is important regarding the installation. The install itself isn't anything too difficult, but some parts of the instructions need to be clarified, some parts need to be highlighted to ensure a smooth install. I'll try to keep it to the point, but these are my thoughts as a former Porsche Master Tech and car guy that has been wrenching for 30 years, mostly for hobby.
Critical tools:
Torque wrench - you 100% need this for torquing the exhaust clamps otherwise you will under or over tighten them guaranteed. This will either cause a leak or damage to the exhaust, so don't skip using one.
The other VERY critical tool was an exhaust hanger removal tool. I purchased mine on Amazon for $14. Never used one before, but would be a pain without it.
First things, lay out the exhaust the way it will be finally assembled. There are a lot of parts since you cannot ship a 12' long exhaust through UPS, so make sure you get everything organized. Having a lift is MUCH better of course, but if you are working off the floor, have a good set of jack stands and wheel-chocks to keep everything safe.
Next, read the instructions thoroughly before starting, maybe even the day before, to let it soak in. It's basic, but there are a lot of steps, and orienting pipes, clamps, etc. Be sure to separate out the pipe clamps because there are several sizes and you don't want to use the wrong one in the wrong spot.
I did 99% of the installation by myself, my wife helped with the stock exhaust removal at the last step, but that was it. I recommend a $89 tower stand from Harbor Freight to assist holding things where you want; it was priceless to have. This only applies to being on a lift, otherwise a couple extra jack stands will help.
The valves: This is the part everyone worries about and have discussed endlessly due to errors with check engine lights, etc. It's actually VERY simple, but you have to mind the details to get it right.
When you turn the car off, have the exhaust in the loud mode, V-Mode, or whatever holds the valves 100% open. When you turn the car off, look in the tailpipes containing the valves and you can see very easily that the valve is horizontal (open). If the car is off, and the valve is open, you are good to go. I did not unhook the battery, I did not need any special scan-tool or anything. (sorry no photo, but it is terribly obvious when you look in)
There is a step that involves removing the nuts holding the rear-most exhaust hangers. My 3/8" ratchet would not budge them, I had to get a 1/2" breaker bar and extension with a u-joint adapter to get at it, but several of these bolts used were installed with thread-lock of some type.
One step that is not mentioned in the Corsa instructions involves the rear splitter. I have the carbon fiber one, and when removing the stock exhaust, it is a super-tight fit to get the actuator valves past the splitter w/o damaging it. I recommend removing the screws along the bottom-middle of the splitter (T15 torx I think?) and let it have some movement so you don't get hung up on it.
After that, it's just start putting it together starting at the front and working your way to the back. The instructions explicitly tell you how much overlap each pipe section requires, so measure accurately and mark with a Sharpie to get it just right. Doing this will ensure that all 5 sections end up in the right place and it doesn't rub, doesn't hang out the back too far, etc.
This photo is after it was completed and the center brace was installed, but you can see how things fit nicely and line up well. Use stands to hold up the middle while you bolt the front pipes on and try to keep things centered.
VERY IMPORTANT: Leave all clamps just snug until the very end. Tighten enough that you can just barely rotate or slide the pipes and make adjustments. Line up with your Sharpie marks to get started and it should stay fairly close to the correct position.
One of the next steps is removing the valve actuators from the old exhaust. When doing so, get out your trusty Sharpie and label them "D" for driver's side and "P" for passenger. They have to go back on the same way. When you pull them off, there is a weird little spring, just keep it oriented the same way as it was when it came out. Mine actually stayed stuck to the actuator and made it easy.
When you install it, make sure the valve on the Corsa exhaust is also in the 100% open position.
When you are inserting the actuator and spring into the new valve, you will see what when it is lined up, the holes in the actuator and the stainless bracket do not line up correctly, which was a tad confusing at first (photo):
THIS IS CORRECT! The spring actually has a little tension when it is installed, so you have to hold it down in place (against the stainless bracket) and rotate the actuator until the holes line up. Carefully install one bolt at a time until all three are started, then tighten to proper torque spec (89 inch lbs I think?)
When it comes to putting all of these random pipes and clamps together, there is a LOT of room for adjustment and twisting/turning of them. The main thing to takeaway from the instructions, is that when you snug things up, have the part of the exhaust hangers that go through the rubber holders be horizontal. Also, the small, flat brace that says "Corsa" has to also be horizontal (level). See photos:
After this, you will find that the support stand is priceless for pushing up on the connection between the two mufflers and adjusting up as high as you can without having the actuators hit anything and keeping proper clearances.
Once everything is "roughed in", then go to the front and start tightening everything to 45 ft. lbs (61 Nm). Check your Sharpie marks and orient the bolts on the clamps up out of the way of any lines, heatshields, etc. The instructions tell you exactly which direction all clamps should face. My only gripe is the clamps on the exhaust tips are kind of big and clunky, but you don't really see them when it's on the ground.
Pro-tip: I spray painted the pipes that slide inside the tips with high-temp flat black paint so that the shiny parts wouldn't show within the black tips.
Spend a bit of time rotating the last two pipes off each muffler until the spacing it JUST right. You will have to fiddle around for a while, but you there is a lot of adjustment, and once you get it correct, no only will it look good, but it will stay that way since everything bolts together so solidly.
After a drive, re-torque all fasteners (after the exhaust has cooled).
SEE POST #2 for the rest.
Continued...
Now, go ENJOY IT! Overall I measured about 1.25" less clearance in the back from the stock muffler, but it's nothing you will ever be concerned with. My mufflers tucked up in quite nicely and then standing back you don't really see them. See photos below showing from different heights/angles:
Tips look great:
Also, if you have random wall-space to fill up, the stock exhaust makes for some fun "artwork":
See post #3 for final thoughts.
Well, I said I would try to keep it short, so total fail, haha. I am used to other car messaging boards where people always share detailed install info, etc. I have benefited greatly over the years on my own projects using the help of others, so this is my pay it forward moment I guess.
My review:
I have installed dozens of exhausts over the years, including some I made on my own, and ones I have purchased. This was the most expensive, but it's not a $30k car either. The quality is excellent, and the instructions for install were about 8/10, so not too bad. I have no weird rattles, had no missing parts, and was able to do the whole job in about 3 hours.
Sound:
This is always the part I am nervous about after scouring the internet for any sound clips I can find before ordering. I don't want an insanely loud/droning exhaust that I will get sick of quickly. I want this car to maintain it's Jekyll/Hyde character, and this exhaust helps do that perfectly. The closed sound is very tame. Outside the car it sounds similar to stock, but when cruising it is definitely quieter than stock, which makes me happy. Stock has a small amount of drone on the highway (even with "My Mode" set to the lowest engine sound setting). The Corsa has no drone and is so nice and quiet it is incredible.
However, when open, it makes you giggle and feel a little evil, haha. It sounds like a badass 'vette you have heard back in the day. It sounds so good and has TONS of pops and crackle on decel when in V-Mode. You can certainly hear it from inside now, and everyone within a quarter mile will also hear it. I wouldn't want anything more (like longtube headers) on it, since it is an amazing balance just like this. I'm sure it gained a couple horsepower, but it isn't anything you will feel.
My only thing I think I want now is an S/C lid that is maybe a little louder so I can hear some whine, but otherwise it's great. I've only been able to drive it for like 10-15 minutes due to more bad/snowy weather this week, but I am looking forward to cruising as soon as I can.
Below is a (not so great) little video I made from the few clips I filmed with my phone after install. I would have better video if I had a camera person, but it was better than nothing.
Feel free to ask questions if you have any. Cheers!
Nice tips.
Is the BW that wide? Or is it the lift? When I've parked my 5 on my 4 post there is room to move still. Yours looks like its about to fall off the side.
Nice tips.
Depends on the lift you have; mine is on the smaller side because I don't care if I ever lift my F350 up. I preferred the extra space in the garage. It goes right to the edge though.
Good idea on painting the "inner pipe" black! That's the one gripe with mine but I'll just put the pedal down more to make it go away.
By the way:
In "tour mode" the exhaust isn't at it's quietest setting. I have the "my mode" set to the lowest "engine sound" setting and it is significantly quieter. The Corsa is silent while driving, "tour mode" is noticeably louder.
Excellent write up , this will be helpful for when I install mine.. the 30-day mark from my order date is approaching in a few days.. has any recouped on that 5% refund from Corsa if they exceed the 30 day mark prior to shipping? Nonetheless this exhaust seems to really turn the appeal on the 5BW up a notch!
I tried to get that rebate, they offered 7% at the time I ordered. After numerous emails and phone calls back and forth, I never got anywhere with them on the rebate and I think that was not an accident on their part.
Sounds like a great company to do business with.
Interesting. I like the idea of making the Jekyll and Hyde even more pronounced. Do others with the Corsa agree that it’s actually quieter in the ~tour modes?
FYI - Tour mode is quiet at low RPM, and gradually opens the valves more as the RPMs increase. I have "My Mode" set to have the "engine sound" at it's lowest setting. With that setting, it is very surprisingly quiet.
Almost at the 1500 mile break in. Congrats.
Yes, diff fluid on the way so I can change it soon. Then I can finally do a good launch:lou
