Noob-ish question on 5BW Oil Consumption
NorCal Blackwing
California, US
2022 CT5-V Blackwing MT (Current), 2012 CTS-V Wagon MT (past)
I've got a 5BW with about 20,000 miles on it. All 20,000 miles were put on by me (well except for the delivery mileage). No problems to-date with the engine (knock on wood). No sign of excessive oil consumption until now.
Yesterday, I went a long, spirited backroad drive, came home and parked up without issue.
This afternoon, when starting up the car, I got the low oil warning on the DIC.
Checked the dipstick at first and there appeared to be sufficient oil on it, though one side of the dipstick had a higher level than the other.
Since it wasn't at the top of the crosshatch I added a half quart and started the car again, but got the same warning.
After leaving the car for 30 minutes, checked the dipstick again and it's bone dry. Added another half quart, measured again, nothing on the dipstick.
There is no puddle of oil under the car...
Booked an appointment at a nearby dealer on Friday - but not sure whether I should be driving it there. Also a bit worried that If I keep adding oil will I overfill if I'm measuring it wrong... a dipstick should be pretty idiot proof but it doesn't compute that the engine would be bone dry of oil even after adding a quart, without a big puddle of oil under the car.
What do you folks think?
The first time the DIC reported low oil and i tried to use the dipstick, i had the same issue. was bone dry. I added a quart, still dry, then another, blah. Eventually it overfilled, so YES, you will overfill it...
I dont even check it anymore with the dipstick. Whenever mine says its low, I just add 1 quart and its been fine doing that until I get to an oil change.
When checking, ensure you are on a very level surface, and wait about 5-10 mins after shutting the engine off. Pull out stick, wipe dry, insert and check.
I'm at 33k, she burns quite a bit of oil... approx 3 quarts between 5k mile oil changes.
I will take it in for 1) oil consumption concern, 2) a creeking when backing up when the wheel is cranked all the way (angling into driveway - creeeeeek), 3) lumbar, and therefore massager, not working on driver side, and 4) in 3rd gear vmode I dont see the shift lights come up (this one im not so sure about dealer testing to confirm - may take a video ). Sigh.
It's weird, my garage surface is quite level and I've taken oil measurements there before. This morning I took another measurement and it looks like there's a very small amount of oil about midway up the crosshatch now (i.e. it's thin, like there's not much there). Go figure.
My V2 Wagon had oil consumption issues and I'd have to add a quart before each oil change, but it manifest itself fairly early on. I was hoping I dodged that bullet with this one.
Yes, with new oil it's very hard to see on the dipstick as it's nearly clear when it is such a thin film. Dry it completely, dip slowly at the last bit of it that goes into the tube. Take out and check front and back of the stick with it angled to the light, and look for the start of the shiny part. That's about the best you can do.
Damn… this is something I have to look forward to? I’d hope that a new car wouldn’t burn through oil after the break in period unless running hard on a track.
yup, gonna go through some oil... just be thankful you aren't driving a BMW M5 with a V-10... it could be a lot worse.
Well shit… I guess I better pick some up before I pick my baby up from from getting the Kavaca wrap. That gives me a few days. Everyone going with the Mobil 1 as directed by the manual or what?
i have a 2022 which has the previous dexos2 in the manual I think, not supercar. but now i guess that's what the dealer puts it in for the prepaid maintenance so i do too.. assuming they use supercar for all BW's now.
Ugh, the S85 is not a promising bar to clear :ROFLMAO:
Thank goodness this car is just so much fun to drive
You’ll be fine. Just drive it 1,000 to 1,500 miles and change the oil. Pick up an extra quart at that time. I haven’t had any need to add oil between changes. Actually. since I do a lot of city driving my oil life indicator only nets me about 2,500 miles.
I changed the diff out at the same time I did my first oil change, but based on what I saw (or more accurately what I didn’t see), it was unnecessary.
Was planning the first oil change at around 700 and another at 1500… I thought that’s what I read in the manual, but I’ll have to double check. Good to know not everyone is having the oil consumption issue. 🤙🏽
are you saying you don't need to add oil because you change your oil every 2500-3000 miles? or you just havent had to change oil in between for higher intervals? I see you are in AZ. I am in Vegas and go through alot in the summer, but I dont change my oil until i get low on oil life per the DIC 😇
I’m saying two things, the DIC oil life is at 5 to 10% by 2.5K to 3K miles when I change my oil and I don’t need to add oil in between oil changes. I’m also a little heavy on the right foot and shift at higher RPMs as much as I can get away with.
Now I'm paranoid. Have to go check my oil level. I'd have to say, mine doesn't use any oil either. I change it when the DIC says too, once a year, maybe 3-4000 miles.
I've still got a S65 oil burner in the fleet! Keeping it helps put any potential Blackwing problem into a better perspective!
Mine is a MY23 with 42k on the odo. I do my own basic maintenance and change the oil and filter when the DIC says. Since 25k-ish, I've had to add 1-2 qts in between oil changes. I run her pretty hard and often see trip digits on my commute so pretty sure I'm the cause of the extra oil consumption. I leave a quart of Mobile 1 Supercar motor oil in the trunk to make sure I'm not stuck without it if needed.
Well, to reset my baseline, upon the low oil warning, I took the car into the dealer for an oil change (oil life indicator was just under 30%). Between the last oil change and the low oil warning, I drove only about 4000 miles over about 8 months.
I'm hoping they just underfilled it last time since I wasn't burning oil at that rate before.
As an aside, with 20K on the odo the service advisor told me I needed to have my transmission and brake fluid replaced so that gives you an idea of this dealer.
