CT5-V Mud Flaps
Rockville Centre, NY
2024 Cadillac CT5V Blackwing
Has anyone installed any mud flaps for the CT5-V Blackwing? I ordered a set for the regular V but not sure if they will work.
Following
ZL1addons if I remember correctly, it was the Cadillac CTS v 2019. But they do the job. Keep rock chips down.
I read that incorrect. So you used the CTS V 2019 version of the flaps on your CT5V blackwing? Do you have pictures of the front inside the wheel well? does it have the indent to line up with the fender lining? That is what i am having an issue with and not installing the generic ones.
Honestly can’t recall, I don’t care to use anything but existing locations so I don’t think so
So they fit using the original holes on the BW? Everything lines up from the V3 mud flaps holes to the holes in the BW fender lining?
Use of one OE hole, one new hole in the oem plastic rock guard easily replaced later if needed.
Ahhh ok understand!
I will order mine then. Just wanted to make sure than I didn’t have to create any new hole in the BW fender lining. Would rather do that to the mud flap itself. Thanks man!
Thank you for your post. Do both the front and rears fit? Is this the product you used?
Even if they worked, deal killer for me bc from their website:
"Do not take your vehicle through an automatic car wash with this product installed unless it is a touchless car wash."
I put on >20k miles/yr on my 5BW and take it thru a car wash at least weekly to keep her semi-clean.
Yes both work
Run our car through touch less wash they haven’t fallen off yet! LOL
Anybody see the flaps from Vicrez? I’ve never heard of them but in the fitment notes it lists blackwing. Worth trying for the price maybe and they list front and rear.
