Drozboyz
So i was contacted by one of the dealers that I am the waitlist on.... Said they can get a build for me but carbon fiber option is the only stipulation. I think CF1 is available (have to confirm) but CF2 is not. From another dealer today I heard that the hold up is with CF2 , the rear diffuser has a sensor that allows you to open the trunk with your foot. That is the piece that is holding up CF2 . If you don't go with CF2 , does that function still work? I asked if I could go without CF2 and add those bits on installed by a dealer once available. Was told no on the rear diffuser because of the wiring involved with that sensor.... I will assume that the other pieces Grille header, Rocker Mouldings, Rocker Extensions can be added at a later date... Do I wait or take this opportunity to get the car........
