vagabond
Elite Member
- Joined
- Jan 17, 2024
- Messages
- 125
- Location
- Washington State
- V-Series Cadillac(s)?
- CT5-V BW Stripper Spec
The Le Monstre 5BW and Petit Pataud 4BW had a very similar blue and black combo. I absolutely loved how that interior looked with the dark blue and black combo. Obviously the way you did it was different, but without the upper section being lighter like that then they are very similar.To me the Phantom Blue interior is the most unusual/different and a little on the sporty side.
Here are my builds and two color samples.
Love the purple with bronze combo.Here are my builds and two color samples.
If I was going all in I would want an actual REAL paint spay out.I’m probably going with the green. I’ve always wanted a green car and this is a specific color that isn’t readily available. I’m meeting again with them tomorrow morning. I showed the images to a friend who pointed out the black in the center of the backseat looks off compared to the other seats. I don’t think I can change the black tho. I want to take another crack at the interior again.
I would disagree with your friend on the black in the back. Looks fine to me, and lines up with the center console. Then it looks like 4 individual seats instead of a bench across the back. Much more premium like that.I’m probably going with the green. I’ve always wanted a green car and this is a specific color that isn’t readily available. I’m meeting again with them tomorrow morning. I showed the images to a friend who pointed out the black in the center of the backseat looks off compared to the other seats. I don’t think I can change the black tho. I want to take another crack at the interior again.
And the other thing to consider is the floor is also black which helps tie it together too. I’m curious what she will suggest.I would disagree with your friend on the black in the back. Looks fine to me, and lines up with the center console. Then it looks like 4 individual seats instead of a bench across the back. Much more premium like that.
After you mentioned it, I asked my wife (who did graphic design) about it. She agreed with the assessment. She compared the 2 different brown rear seats. In the first pic, the seats are brown with gray inserts and have a black bar separating them. In the second pic, the black on the right and left sides make it so the seats are black with brown/tan inserts. Basically, the black sides frame the seats so the black center now becomes part each seat instead of a just a separator. I hope that makes sense. Making the sides black might be the change you need to make to make it work with the black center console.I have another meeting tomorrow morning. I asked a friend who didn’t like the way the black looks in the center of the backseat. I hadn’t been including it in my thinking. It does kind of look off. I need to incorporate the black better into the seat. I can’t do anything about that center rear seat. The concierge has an idea or two for me tomorrow.
