Ceramics
I've tried the ferodo DS 2500 and they're really good because I used them as my track brake pads back in the day on my Scion FRS which is now known as the Toyota gr86 or Subaru BRZ.
Thanks for sharing. Nice to hear that you also have great experience with the Ferodo DS2500 as a track pad. If it has less brake dust than the OEM ones, then I might just get the Ferodo DS2500. As I mentioned earlier, now I’m stuck between getting the Carbotech 1521s or the Ferodo DS2500.
Was wondering what everyone’s opinion is on the GiroDisc 2 rotors? Anyone have them or know about them? Is it significantly better or worse than the stock rotors on the 4BW?
On the Corvette forum which I used to be a part of, everyone was saying good things about gyro disc brand.
I am a huge Ferodo fan. Not just of the DS2500 but also the DS1.11 and the DSUNO. Those are the 2 other compounds I have tried on the GT350. If you want to go a bit more aggressive on the compound, the DS1.11 are great. Better wear on the track and way less brake dust. No free lunches though. They are a bit harder on the rotors and require just a bit more temp to work well on the street. And they cost more. If you are doing serious track time, I would run the DS1.11 over the DS2500.
I have not run the new DS3.12 but they sound great as well.
Thanks for your insights. I don’t do too much tracking, but do so occasionally. Do you think the DS2500 are good for aggressive street driving with light track use? How’s the brake dust compare to the OEM pads on the 4BW?
Wow! That’s a very nice setup you got there. Given the setup are both on all front and back wheels, that’s half the cost of a BRZ. How do you like the CUP 2 Rs?
I haven't had much experience yet with them since I just upgraded a few days ago from the 1lz z06 to the 3lz z06 with z07 package which included these tires specifically. I'm sure these are more track oriented tires and they would be better suited to high performance track driving when the weather is a bit warmer and dry out there. I really don't need these aggressive tires on the street but out on the track I would say otherwise because they could prove more useful there in that environment.
I've owned a BRZ, and those have gotten mighty expensive at close to $40,000 especially if you want the proper TS version with upgraded brakes.
Gotcha. I wonder how much different it compares to the OEM rotors on the 4BW.
Well I bet there's nothing like peace of mind and proven reliability for street driving with what comes OEM but things could change when it comes to high performance driving and where aftermarket parts could come in more up to the task like the brake componentry.
If you do only occasional tracking and don’t run race tires then the DS2500 are the right pad for you. I cannot speak to the brake dust compared to stock CT4 pads as I have a CT5 with the carbon ceramic rotors. But on my GT350 the brake dust seemed similar to other pads.
As others have mentioned the OEM rotors and pads sound like they suit your needs other than the brake dust, and it’s questionable if a replacement pad that fills your need has more or less dust. Have you considered ceramic coating your wheels instead, making them easier to clean? The OEM pads are good for the street and pretty great on track.
I’m sure you can make use of the Cup 2 RS driving around the canyons. But if you’re doing some street driving on your 3LZ, I’d switch out the tires since the Cup 2 RS will wear very quickly since they’re meant for the track. I’d say use the Pilot Sport 4S for everyday driving and save the Cup 2 RS for whenever you hit the track. My opinion only.
Yup that’s true - can’t go wrong with OEM. Cadillac has proven their OEM brake system to be excellent on the streets and on the track.
I’m leaning towards the DS2500 since you’ve previously mentioned that it’s a great pad for both street and track use. As Super Saloon mentioned above, I’ll just ceramic coat my wheels so the brake dust comes off easier. That’ll solve worries with brake dust.
Thanks for suggesting ceramic coating…didn’t know why I didn’t think about that from the beginning. Also, as much as I like the OEM brake system on the 4BW, I’m leaning towards getting the GiroDisc 2 for rotors and the Ferodo DS2500 for pads. Worth giving it a shot just to see how it compares from the OEM rotors and OEM pads.
I just did this! Its a lot of work. but I'd never tried jacking up the car before. That took awhile to figure out :-/
I wish I'd seen this video prior to selecting Gtechniq C5. We'll see how it holds up.
Thanks for sharing. Wow! 80% less brake dust…that’s a big difference. Now I’m debating on whether I should get the Ferodo DS2500 (for street and track use) or the Carbotech 1521 (for significantly less brake dust). Have you or anyone else used the Carbotech 1521 on the track?
Carbotech is very emphatic that the 1521s ARE NOT for track use.
There's not much recent discussion on this topic, so I thought I'd revive this old thread. The conversation was mostly about ceramic pads on iron rotors, but there was some discussion about carbon ceramic brakes. Here's my opinion based on everything I've been able to learn so far. I haven't actually ever driven with CCB, but really, how different could it be? Challenge anything you want, as discussion and learning is an ongoing process.
Touching first on the topic of heat. CCB make less heat that iron brakes under braking. CCB dissipates heat faster than iron brakes. CCB operate at lower temperatures than iron brakes. Although CCB operate at lower temperatures, they have the capability of tolerating heat far exceeding what iron brakes can tolerate. This last thing doesn't seem very important because I haven't been having a heat problem on the track with iron brakes.
The guy tracking his car wants CCB more for handling than braking. Taking 15lbs off each front and 10 lbs off each rear wheel of unsprung weight will improve the cars handling capability. Let's say you're now 1-2 mph faster into every corner, out of every corner and 1-2 miles an hour faster on every straight section. Primary secondary benefit is longevity, probably lasting 3x the life of iron rotors. Beyond that, there's some increased braking capability if you using the track specific carbon ceramic pads and lastly there's less brake dust. Well, I guess not quite lastly, because the 20lb reduction of rotational mass of the rotors will yield a 2-3 hp increase on a chassis dyno.
For the guy just driving on the street, his primary reason for wanting CCB is to eliminate brake dust. Primary secondary benefit is 3x life over iron rotors. Beyond that, eh, that guy is not driving the car anywhere near it's capabilities on the street, so what's the need to increase it's capabilities?
So it seems to me that with CCB it's about eliminating brake dust, or going faster and eliminating brake dust. But there actually is more, and that comes back to the 3x life expectancy. If you're comparing an OEM set of rotors and pads for $3,500 versus a $10K GM CCB package, the 3 to 1 cost matches, the 3 to 1 life, so where's the incentive to go CCB. Rather than comparing a situation where GM sells you a $3,500 part for $10K, just buy the $3,500 part direct from the manufacturer? So, it's $3,500 to replace with OEM iron, or $3,500 to replace with "aftermarket" CCB. I put the quotes around aftermarket because it's not like GM makes their own CCB. They are made for GM by a Chinese company.
Here are the first CCB made for the CT4-V Blackwing. The 380mmx34mmx70mm ring is a standard size, so only the hat had to be custom made for the fronts. You can order the hat in a range of colors. With both street and track specific carbon ceramic pads, that's an $1,800 set.
I agree the Carbotech 1521s are a great option, definitely significantly less dust. I had PowerStop pads on my C8 and they would be my first choice but they aren't offered for the CT5-V BW.
