$20k Budget for Stock 2024 CT5-V BW
Gonzo
Virginia
2024 CT5-V Blackwing
Looking for some help in selecting the best bang for a $20k budget for my 2024 CT5-V Blackwing. Wo
What say you?
Below is what I'm considering so far. I'll also have to pay for labor as I'd rather have a shop do the complete work.
  • Supercharger Gasket Kit​
  • Kong Xport Service​
  • 2.3" Pulley​
  • Gates Green Belt​
  • Nick Williams 103mm Throttle Body​
  • DSX Fex Fuel Sensor​
  • DSX Fuel Line Adapter​
  • NGK Spark Plugs​
  • HP Tuner MPVI Interface​
  • HP Tuners Credits​
  • HP Tuners ECM Unlock Fee​
  • Schmidty Tuning Fee​
  • Dyno Tune Vehicle​
  • Aeroforce Gauge and Pod​
  • LMP Cold Air Intake​
  • LMP Heat Exchanger and LMP Coolant Tank​
  • Kooks Headers with Cats and Mid Pipes​
I must be getting really old. I bought my 22' 5BW and will do absolutely nothing to it. To me , its perfect right out of the box. I have found in my years of owning cars.....the more you eff with them, the more headaches you get.
I learned that lesson the hard way with a 2013 Camaro ZL1. I got caught up in the forum hype around mods and thought a cold air intake and bigger crank pulley would be my ticket to muscle car nirvana. Well, one thing led to another—bigger injectors, labor, tuning, dyno time—and nearly $10K later, I had a car that never drove as well as it did stock. I went through five different tuners trying to sort it out before finally taking it back to stock, aside from the cold air intake.
Since then, I promised myself I’d never touch the engine or tuning again. These days, the only changes I make are cosmetic—wheels, carbon fiber bits, things like that. Nothing that compromises how the car runs.
So i asked Bill at RPM
there stage 3 kit is 19 K
Stage 3 - $19,995.00
they just did a Camaro with same package, and was i believe like 795 RWHP
that's no meth no E 85 nothing this is what i would do but add expansion tank for more cooling and a Monster triple clutch that's it
Package includes listed components and full professional installation:
  • 2” Kooks Long Tube Header System w/ Off-Road Connection Pipes
  • GM Exhaust Manifold Gasket (2)
  • NGK Spark Plug (8)
  • RPM Custom LT4 AFM Delete Camshaft Package (Includes - RPM Custom Spec’d Cam w/ Increased Fuel Flow Lobe, Dual Valve Spring Kit, 3/8" Hardened Pushrods, ARP Head Stud Kit, GM Timing Chain, GM LS7 Lifters w/ GM Lifter Trays, GM MLS Cylinder Head Gaskets, AFM Delete Valley Cover, VVT Phaser Lockout, GM VVT Cam Bolt, GM Crank Bolt, GM RTV Sealant, Mobil 1 Oil & NAPA Gold Filter Change
  • ATI 15% Overdriven Harmonic Balancer
  • HD Supercharger Belt
  • Kong Performance X-Port CNC’d Supercharger Porting w/ 2.3” Supercharger Pulley
  • Cordes Performance 4.5” Cold Air Intake
  • Custom Global B ECU Calibration using HP Tuners
Includes baseline before and after dyno results with printout
Automatic Transmission equipped vehicles add $500.00 (Includes TCM Unlocking via HP Tuners)
