I gotta know what makes this filter a knock off? My filter looks identical to it. What makes you think its a knock off??Be careful ordering filters from Amazon. I got a knock off. View attachment 24682View attachment 24683View attachment 24684
Not my photo. But similar to what I received. On the left is a store bought filter. On the right is what was sent by Amazon.I gotta know what makes this filter a knock off? My filter looks identical to it. What makes you think its a knock off??
I just checked the filters I have in the garage. I have a PF64 from Amazon and a PF63 for a Yukon XL and both have the same look as the PF64 on the right hand side. My guess is the design changed. You have two different part numbers there as well so that only helps to support the hypothesis that ACDelco updated the end cap design.Not my photo. But similar to what I received. On the left is a store bought filter. On the right is what was sent by Amazon.View attachment 24703
LS6-M22 is correct and recently another new part # will surface when typing either of the two others - 25206377Yeah those two filters are real GM filters just the one on the right is updated. When I did my oil change I removed the factory filter and it looked just like the one on the right
Reviving this thread. I know for the oil filters, Tapout tuning recommends the upgraded UPF63R, and the manual just calls out for the PF63. I thought the UPF63R oil filter was for increased flow and filtration, but I see the PF63 has more flow holes than the UPF63R when I was doing the oil change... anyone know why?
I know this was from a long time ago but does anyone know the answer?I’m curious, does the 4BW still require 0W40 for track use? The C7 was that way.
