Grainofsand
Oh my goodness. The road noise in this car is very noticeable
. It must be the wider tires and lack of insulation. Anybody planning on adding some sound deadening material to the interior?
Are you on the factory Michelin Pilot Sport 4S? The road noise is most noticeable at highway speeds. Around town it is fine.My 4V Blackwing has almost no road noise, very quiet other than my exhaust popping
I think the ANC only cancels out engine noise. But I want more of that. Less tire noise.Y'all must have 3rd world country roads. The cabin noise is great in-town and on the highway. The ANC does its job. I'll have to use my dBA meter on my phone to check and compare to my daily E90. That one definitely has more road noise but nothing too bad either.
I thought OP was kidding..........I think its very quiet. Sure, some road noise creeps in when driving over more gravelly-type asphalt, but overall very quiet.
I pulled the fuse for the stereo/ANC, and also pulled the fuse for the exhaust, and in a short city drive could not really tell any difference.
No I have no reason to kid about this. On the highway it almost sounds like it's howling. Almost can't have a normal conversation on the highway. (slight exaggeration)
It is quiet on nice roads, but nice roads are rare. It's also relatively quiet at lower speeds.
Like someone said, maybe it's the tires. Maybe these tires are just kind of crappy when it comes to road noise. My C7 stingray had wider tires in the back, but they were PSS and weren't this loud.
Have you guys tried driving it at highway speeds?
In San Antonio, if I'm driving on 1604 = low roar + low vibration in sections. If I'm on IH10 = quiet and smooth. 410 = same. Road outside my neighborhood = loud (no car I've owned has been exactly quiet on this stretch). Newly paved 211 = quiet and smooth.CT5 V blackwing should not be louder than a C7 with PSSes. Something is not right with your car. Like I mentioned prior, most likely one of your tires has a bad belt.
I drive the 5BW 110 miles a day on the highway, averaging 85mph or alot more if the roads open up. It's whisper quiet at speed.
Are your highways typically asphalt or concrete? There is a huge difference in noise between the two.No I have no reason to kid about this. On the highway it almost sounds like it's howling. Almost can't have a normal conversation on the highway. (slight exaggeration)
