Steering Wheel Spacer / increase Telescoping
sgray944t
Georgia
Hi All - new owner of a 23 Blackwing here. One thing that I’ve seen mentioned here before, and experienced myself, is a desire to bring the steering wheel closer to the driver.
I’m very aware the car has a telescoping wheel, but for some of us tall drivers it would be great if it came out another inch or 2 from its current max.
That would also give more right knee room from the lower corner of the center stack.
I’ve done a ton of digging and don’t see a product that offers this, while keeping the stock wheel and all functions. That is non-negotiable to me, needs to keep the wheel itself stock. There is this place in Italy that sells to many speed shops, and seems to be the best thing I’ve found that would accomplish the goal and keep the stock wheel. I contacted them to inquire about developing a Blackwing spacer, but never heard back. Example of an F80 M3 spacer they sell: BMW 3 Series F30 M3 Steering wheel spacer
So…generally a question of has anyone else looked for and found a solution? Granted it’s a small market of an already small Blackwing market, but I think some of us would be willing to spend a little to improve the ergonomics.
I’m not an engineer or fabricator, so curious if anyone out there wants to take on the challenge or has some insight to share?
I contacted the same company. I also never heard back other than receiving an obviously AI generated email when I asked if their Covette spacer would fit a CT5.
I agree that more telescoping is definitely needed for tall people. I would be in for a well designed spacer like the ones from that Italian company.
Thanks for the reply! Agreed their design looks great. Honestly someone with some CAD and fabrication experience I’m sure could figure out the physical spacer. What also would be needed is likely a jumper harness or something for the wiring.
For the price, I would be tempted to buy the C6 one and try to see if it fits. If not, find someone local to modify it accordingly and go from there.
Thought about it, it’s just at least a decade different in design so figured a long shot. If they had a Camaro version I’d 100% agree worth a shot. Anyone whose put on an aftermarket steering wheel have the oem to take some measurements and spline count?
  • Like
Reactions: Z28
Small update for the few of us who are interested :). I've been emailing with Spacershop and they did actually reply and said they could make the spacer. I sent him a ton of photos of the Blackwing wheel, hub, steering shaft, etc, and he did some investigating and said that this spacer would technically fit (same spline layout). Its for a Holden Colorado pickup truck (different than Chevy Colorado): Holden Colorado RG Steering wheel spacer
However his next point was that the wiring complexity of the blackwing is significant. Looking at the wheel, we have a large yellow connector that seems to house all of the steering wheel functions. If it was possible to get a Male / Female connector, it may be possible to fabricate a jumper harness...but this is not something he has much interest in doing as the demand is fairly low.
The yellow steering wheel connector appears to be used in a ton of GM products, so these must be available somewhere?
I'd check with parts yards/dismantlers about trying to source that connector. A matching pair from a wreck or airbag deployment vehicle should be useable. You may need to buy a damaged wheel/column setup however.
I had the same thought, could strip a steering column and steering wheel.
Thanks for updating us! I was just thinking about this a couple of days ago. Great you heard back from them and they already have a spacer that would work if we can source our own wiring.
Damn that is a lot of wires in that harness. Most companies offer repair wires that have the right ends to click into their harnesses. If someone is a GM parts expert, maybe they can help with that and also with the part numbers for the male and female connectors.
Yep that looks like it to me. I also found this which appears to be the male side and harness, though the description says no heated wheel and references the wrong # in the image: https://www.gmpartsonline.net/oem-p..._VrhXBoQMY0TUAnNbxb8wbrUcOYpmY5IMlSFsMhjG5Ask
One thing I’ll say about BMW…all of their parts diagrams are available for free online (realoem.com) Why am I not finding that for GM?
On the female side, might be a little trickier since it appears to be a part of the clock spring assembly: 2020-2024 CADILLAC CT5 STEERING WHEEL CLOCK SPRING OEM | eBay
Honestly I feel like this is pretty achievable. The male connector and harness could be used as a jumper and we just need a female connector to wire it into. I could buy a clock spring and try taking it apart, but would really like to see if it’s available on its own AND check the actual PIN out / wiring diagram.
Is the only way to access the legit diagrams by paying for a subscription to AC Delco TDS? I think I read at one time someone was able to buy like a 5 day subscription for a nominal amount.
I ordered a clock spring and steering wheel wiring harness today. I’ll take them apart and see about mocking up a jumper harness. If that’s do able, I’ll order the Holden spacer and give it a shot.
That is awesome! Thanks for taking a shot at figuring this out. Let me know if there is anything I can help with.
