CT5-V What are the torque specs for the front and rear brake caliper mounting bolts?
thefleshrocket
Carbondale, IL
I'm in the process of installing carbon ceramic brake rotors and pads on my 2023 5BW. I've ordered replacement caliper mounting bolts, since they are single-use, torque-to-yield.
11570092 - Front Disc Brake Caliper Bolt
11610905 - Disc Brake Caliper Bracket Mounting Bolt
I haven't been able to find the torque spec for these bolts. If anyone has that information, I'd love to have it.
Also, from what I understand, the front bolts come with loctite already installed but the rears do not. I recall reading that I should install red loctite on the rear bolts. Is that correct?
(I will post a thread about the CCBs after I get the project done and have some driving impressions. They are rotors and pads that are direct replacements for the iron brakes, so no need to get new calipers or knuckles or what-not. I ordered them from Khoa Nguyen. I've got everything installed, just awaiting the bolts, which should arrive today, so I can finish off the install.)
I can’t imagine red loctite is specified for bolts you ever plan on removing. That requires serious heat to break the bonds. Blue loctite would be what is typically used for bolts you plan on removing in the future. If the fronts have thread locker pre-installed then just see what color it is and use the same on the rears. I am betting it will be blue.
It is red thread locker already on the front bolts. Manual says to reapply high temp red if reusing the bolts. Off memory, rear bolts don't have the thread locker pre-applied, so you'll need it in hand even with new bolts. I think it's 272, whichever one is high temp red. You could skip this step, but you never need thread locker until you really do...
111 lb ft + 15-30° front
74 lb ft + 15-30° rear
Thanks, I used those torque numbers when installing the new bolts. The front bolts did have thread locker on them, which was colored red, so I assume it's the "OMG you aren't ever going to get this off" stuff.. which would explain why the stockers were so hard to remove. I used blue loctite for the rear bolts.
