CT5-V Blackwing Suspension Tuning - Options, Specs, Reviews
Toe is all in spec, .1 all around from my alignment. The camber up front made the car incredible in the turns , first year I went i have understeer issues with 1.5 in the front. Went last year and 2.3 gave way more grip in the turns but then the rear end felt loose. Now the car feels incredible, I just want more of it lol.
I'm probably going to drop into Washington State from Oliver, BC (below Calgary where Area27.ca has a track with Blackwings - never been there) Big windies and swoops in the Rockies and Tetons ahead. Is there a bone stock CT5-V alignment you could suggest as if you were doing the Tail of the Dragon all stock? Thanks.
Your white Blackwing is looking terrific!
:_rock
:_rock
Thanks !
Bone stock I'd have the track alignment setup for canyon runs. It will help keep understeer down, have the rear camber as much as you can as well. With rear factory arms and toe bar you should be able to get 1.25-1.5 camber. If you wanna keep your tires from wearing afterwards I'd align it back to street spec when you get home ( 1.5 front 1 rear )
Depending on how comfortable you are with the car I'd run in PTM Sport , otherwise I'd run in Race 1. I tried Race 2 last year before I did my rear suspension build and Race 2 felt like the rear wanted to step out to much.
Ok great, that helps! Looking forward to PTM Sport. I'll start out with Sport 1, PTM Dry, Wet if it rains or, Touring. I will definitely try Race 1 when I get a better feel or some track time. Thanks again 👋
Have fun man ! Pace yourself , the car is easy to over drive since it brakes and accelerates very fast ! Take your time getting used to it, you won't regret it !
When I had a C6 Z06, I found a Pfadt alignment sheet for various goals from street to track. Anyone have something similar to give an alignment tech? Would love to have an aggressive set up but still go easy on the tires. Seems like toe-in really eats the fronts up. I have a precision package on order. I have also test drove one on the street and it doesn’t noticeably ride differently than a regular BW. You do feel imperfections in the asphalt in tour mode though.
What is the full street spec alignment supposed to be and where can you find this info?
I only have the V-series track alignment recommendations. No idea what the street settings should be.
Thanks !
So your Street recommend is
Front camber 1.5
Rear camber 1.0
Front rear Toe .1 (is that toe IN or Toe OUT)
My most recent alignment feels a little squirmy at high speed.
