Blackwing Child Car Seat Fitment
00 Scrub
CA, USA
I was looking at getting either a CT4V BW or a CT5 BW and was wondering if folks had any experience with infant and rear facing car seats in them. I was able to check out a 4VBW today at Carmax and the carseat fitment was a bit tight. I'm guessing the 5BW is a bit better, but was wondering if folks here had first hand experience using their BW as a kid hauler.
Is there a measureable difference in rear seat room between the various tiers of seats?
Thanks
I would recommend getting a larger vehicle than a ct5v blackwing, but no less than the ct5. I would spend similar money and get an Escalade but that's just me. I've been through my share of compacts and having three kids. Better to be more comfortable if possible.
I don't think I can go larger than a CT5 and I want some row your own fun hence the BWs. Otherwise I would consider an e63 AMG wagon or RS6 Avant.
I figure for one kid a car like the CT5 should be more than enough (I've seen folks do just fine in something like a Civic Type R), but if feels like the CT4 just won't fit what's needed for longer trips. Would love to hear if I'm wrong there though.
I grew up in an sedan Deville so I figure the CT5 should be about right.
Your thoughts are spot on.
How tall are you? How many kids?
I have a feeling the 5 is going to be the way to go.
They're are plenty more threads in here discussing this if you search various terms.
Also, you can find a dealer with any ct5 (measurements are basically the same) and bring your car seats to try the fit yourself (I did that before buying my SS sedan and Audi S6... didn't need to by the time I got my 5bw b/c I was towards the end of my last child being a car seat, so I put it forward facing on the passenger side behind my wife without issue)
When you're dealing with rear facing seats the fore and aft of a backseat is really important. It's quite amazing how hard it can be to get car seats in correctly if you're tall. I had a VW Golf R and got 3 kids across and 2 were rear facing. That car had about the same space as a Ct4, but was better for that than the CT4 is due to the how much the wheel wells come into the back seat area.
1 car seat rear facing in a CT4 will be fine on the passenger side with seat moved forward. A passenger will be fine, but might be a little tight if they aren't short. If you have to do 2 rear facing toddler seats then it is going to be hard in a ct4, but doable if you're good with car seat fitments. Infant seats are a lot smaller than rear facing toddler seats if you didn't know.
In my experience Diono makes very good seats that don't take up too much room side to side or fore and aft.
It was a PITA to remove and reinstall the seats in the golf and while possible I now find myself wanting a bigger car to avoid that hassle. If you have 1 or 2 kids then car seat fitment is not too big of a deal.
I have one of the largest car seats on the market because it's swivels 360° for easy in and out. It fits just fine in my 5BW
I have a rear facing convertible on the passenger side rear of my 4, and a front facing toddler-booster behind the driver's seat. It's tight but the front passenger seat is still usable, as is (obviously) the driver seat.
It works for day-to-day, but we also have an SUV which we use when we need more space. I would not have the blackwing as my only car, just because of all the stuff kids require particularly when travelling.
Another point of note, I first tried a front facing convertible behind the driver when tge
I've sat in some CT5's and there is a healthy amount of extra room relative to the 4.
ETA: Setup looks like this, if it helps.
Same height and family size here. CT4 won't work. I'm surprised you say the CT4 was only a bit tight. It was a total showstopper for us.
More detail here: Media dumps
Rear facing in a CT4 here. Seat is behind driver. Fitment is snug but I am able to use the driver seat exit memory to stop just before contact with the seat. The car seat is a Graco Extend2fit. Works fine for us, but agree with above, if the 5 is in budget, get the extra space.
Thanks for the replies y'all. I'm 5' 10". We test fit a infant car seat and it had like 2 fingers of space so an toddler seat might be a bit tough. I think I'll have to go with the 5 if I want to do any sort of road trips (SF to LA and such). Now I need to go find one with a MT and the bucket seats to make sure my wife is happy with it.
Check out the RS6 Avant that you mentioned, if you can. Should have much more space and versatility. I still think the ct5 v Black Wing is a tight fit with car seats. You can do it but there are better cars for the job. Check out a performance suv if you can. So many great cars out there with so much more space. Some of them can have great power and be fun to drive as well.
Hard part is it looks like he wants a manual tranny, which massively limits choices. This was my situation with a car, but luckily I'm in forward facing seats now.
Diono is not too bad for fore/aft space. It really depends on what infant seat you have, it is is Graco KeyFit then that is pretty narrow and short (fore/aft) seat.
Some tricks to make things work is use towels, etc to help pad the lower seat to get the toddler rear facing seat a little more upright, but keeping it within the acceptable range. The more upright it is the less fore/aft you need. But keep it in the correct angle range for them.
Car seats with bars/spacers that push the seat away from the upright section of the back seat usually require more fore/aft space. It has been a few years since I have had figure what would fit having 3 kids within 2.5years of each other, but when I at your stage with kids I found many seat manufacturers did not not disclose the fore/aft dimension needed. Contacting them I was able to get measurements without buying. Now that Baby'r'us is no more I don't know where you can go to get a seat to try it in your car without having to buy it first. Amazon has a good return policy to allow for a buy & test fit, but not all brands are available on their site.
If you only have 1 kid being a toddler rear facing seat and can have the passenger front seat moved a bit forward and more upright then you will be fine with a CT4.
My 2yr old loves riding in the 5BW. Plenty of room with rear-facing Graco Extend2Fit.
Thanks. I'm planning to get the Graco Extend2Fit as well. Right now only 1 kid, but maybe 1 more in the future. I plan to keep this car for at least 10 years (I hold onto cars for ages) so I would want it to accommodate forward facing and booster seats.
I'm on the fence right now between the 5VBW and a CTR. Somehow that civic has insane amounts of room and Honda sprung to calibrate adaptive cruise control for it.
I went through the same dilemma about a year ago. The FL5 would have been my I wanna save some $$, but still have a fun manual with enough back seat space for both front and rear facing car seats. I would see FL5s all over when I lived in Japan so the styling grew a lot on me. I still want one in SGP or Boost Blue. But at the end of the day, it's really fucking tough to beat a 5BW as a great all-around fun car. Even though it's relatively quiet in the cabin, the sound alone is miles above the Civic. Sound is a huge thing for me so I didn't want to go too far out of my way to find an FL5 at MSRP when it was going to be my "I'm settling for this" car. It might be different now, but back then all the dealers I reached out to in CA wanted $60K+...for a fwd Civic.
As always definitely go test drive both if you haven't yet. I know they're not easy to find let alone test drive, but if you can swing to find used ones to take out for a spin you'll know right away which one is the better option for you. Both are fantastic cars in their own way, so you really can't fully go wrong with either one.
