Ceramics
Los Angeles
2023 CT4-V BW
I feel stupid asking this question cause I consider myself a car guy and should know an answer to probably a simple car question.
I’ll be needing new brake pads and rotors soon - can anyone please tell me if I need special rotors to run ceramic brake pads? Or will stock rotors be fine? Also was wondering, would I need to change the calipers to run ceramics?
Please share what brand ceramic brake pads and rotors you all have and/or recommend using. I was thinking Windhammer or Redstuff for the brake pads and GiroDisc 2 for the rotors. Sorry for the dumb questions. Thanks for all your inputs.
Not a dumb question and I'm sure several will have some more questions and I was curious to know myself so thanks for asking.
I did a quick search and I found out that if you're going to install ceramic brake pads then you will need to make sure that the cast iron rotors are in good condition.
It doesn't hurt to get a full ceramic brake pad kit and I've heard good things about gyro disc but haven't tried them personally but this is from my reading up on previous forums.
Good luck with your further research and decision. Hopefully you get some more solid feedback on your thread here as well.
Thanks for your insights! I did get some clarity from Marcmac and he’s using iron rotors with Ceramic pads. Might end up doing the same, but will continue to do research and also hear from others within community. Thanks again.
Put the 4BW on the search page on kns and pads will pull up.
Gotcha! Thanks man. You having no issues running ceramics on iron rotors, do you think it’s worth the extra cost on getting ceramic rotors? I daily my 4BW, but drive aggressively lol. Is there a significant difference between iron rotors and ceramic rotors to justify the price difference?
Are we confusing ceramic & carbon ceramic?
I run ceramic pads on my performance cars to eliminate brake dust for street driving. A good set of ceramic pads will eliminate brake dust by 80 to 90 percent because it sacks driving 10 miles and the wheels get filthy.
Ive never had an issue with iron rotor and ceramic pads.
Nice! Yeah it’s crazy how filthy my wheels get from daily driving it from all the brake dust. Definitely might go with the Ceramic Brake pads because of that. Now I’m debating whether to stick with iron rotors or switching to carbon ceramic rotors. Thanks again for your inputs.
