Launch Control Not Available and No Line Lock
OLoft
DC/MD/VA
Hi,
I recently crossed the 1500 mile mark on my CT5BW and wanted to try the launch control feature. The problem is its showing "Not Available" under the Launch Control menu. I've tried it in VMode with the traction control off and I've messed with all the PTM options, but Launch Control is still showing "Not Available". Am I missing something here?
I also cannot find the Line Lock option as specified in the manual. I thought it would be under the same section as the Launch Control, but I only see the Lap Time, Launch Control and G meter.
Any help would be appreciated.
LC and Line Lock is only available in Race 1&2 IIRC. If you are in Race 1&2, you should be able to scroll to the Line Lock screen and it will be available.
see the screenshot from the manual
launch control should be available in vmode... for the manual trans cars, you just put it in 1st gear and depress the clutch and stab and hold the gas while you hold the clutch in....
You can actually get LC in any mode as long as PTM is enabled. I was talking just about line-lock in that particular instance.
I don't believe you need to be in the Race track modes? IIRC you just need to have one of the PTM enabled. I thought we did it in Sport at Spring Mountain?
Hi,
Any updates on fixing this issue ?
FWIW my 25 ct5v has the same issue, no matter what I set the "conditions are not met"
I have the same issue... no launch control. Tried seatbelt, next will try a wider longer road. No dog on backseat... ?? Then it goes to the dealer for the Launch control, and the Super Cruise that isn't working either 3800 miles...
2025 BW with Precision Package LAUNCH CONTROL - Somewhat Figured it out, I think this is the or my additional checklist after you press the Launch Control Button and the options are not highlighted for use: Must be in TRACK Mode, before you put it in V-Mode. Make Sure your Seatbelt(s)are/ is on; I had my dog in the back had to fake click it (No I didn't LAUNCH with the Dog in the Back !) Steering Wheel Straight, foot on Brake, nothing in front of you, played with Traction Control Button (Held it Down until both Traction Control and Skid Control light came on (see pic attached) until and my options Finally Highlighted. You can choose AUTO or CUSTOM LAUNCH, and LINELOCK is also available to warm and wear out your tires ! P.S.- Love the Linelock prompt ! (see pic) "Release Brake. Floor it."
