Marker Light Removal
Ty88
Florida, USA
2023 CT5 V Blackwing - totaled in accident. Ordering a 2025
Can someone describe for me how to remove this fender marker light? I removed the inner fender torx screws to gain access to the backside of the light but don't see how to remove it from the fender. Thanks.
There are tabs that need to be squeezed then pushing the lamp assembly away from the car. Below is a photo from Amazon you can see the tab on the right side.
Funny I just did those today. Here are basic instructions for 5BW (or any CT5 I assume):
1. Turn wheel all the way so you can access.
2. Remove 4 screws in the front of the wheel well (requires a small torx bit, don't remember which size). You may need a shorter driver or ratchet with hex adapter for top one.
3. Pop out liner a bit. I would suggest using a plastic trim tool if possible.
4. Once you can pull liner out a bit using a flash light you can kind of see what is going on.
5. You just need to unclick the one double tab, first push down on the top bit and you will probably hear small click, then push up on bottom bit and you should hear another small click and then push it out. If this doesn't work you may need to push on both sides at the same time.
6. Push marker out so you can access connector.
7. Push a screw driver into the area with the red tab to push the red tab in then use screw driver to push up black tab that's touching the marker and pull out connector.
8. Connect connector to new marker, pull red tab out how it was.
9. Put bottom tab of marker in first then push top in until it clicks.
10. Put liner back in and screw back together.
This literally will take about 5 minutes per marker. Its pretty simple.
Many thanks everyone.
I did mine when the car was jacked up, wheels off the ground and then access is very good (no need to turn the wheels).
Funny I just did those today. Basically:
8. Connect connector to new marker, push red tab back.
This worked perfectly. Thanks so much.
Oddly enough, the CT4-V BW uses a screw....just FYI for people thinking these will apply to 4's as well as 5's, it mostly does but there is a screw you need to get off and then re-apply to the new side marker.
For those in the future stumbling across this thread via google or whatever search engine/LLM, this video has important information and visuals for those who may not be comfortable yanking on the edge of their bumpers:
For those with a '25+ CT5, Savage told me they will have side markers available for our cars by end of May. I was told that around mid-April, so we will see in the next week if their estimate is correct.
Another option is tinted film. I purchased mine on Amazon along with tinted film for reflectors in rear diffuser. Cheap at about $10-15 a set. Fit was perfect. I just hit them with a heat gun after to get the film to fit tight over the raised print on lens.
I've had the Lamin-X tint on my front side markers, tail lights, reverse light and rear bumper reflectors. Perfect fitment, decent prices, easy to install (though tail lights took some time). They still look great even after nearly 3 years. Unless you get very close up to them, you can't tell that it's a tinted film.
Though the site says 2020+ for the CT5. I remember reading somewhere that the front markers changed on the 2025 as a result of the front end refresh. So they may not have caught up to the 2025 yet.
I started with cheap eBay film but then went to the smoked LED markers. While the film held up very well, I just like the look of the LED markers over the stock ones. With the film, the stock ones were still orange when lit. The (white) LED made it look more cohesive with the rest of the vehicle.
LED side marker:
LED side marker:
Side Marker with film:
Side marker with film:
I *just* joined the forums, but it’s good to know that my installation video is coming up on search results and that, hopefully, it can help some folks on here!
FYI. Latest estimate for 25+ CT5 is mid-to-late July.
