OEM 4BW Graphite replacement wheel - part numbers?
turbospecc
Philadelphia, PA
I did a search and couldn't find anything, but I'm looking to pick up an OEM set of 18" 4BW Satin Graphite wheels and am having a bit of trouble confirming I have the right part numbers given the lack of helpful information on parts.gmparts.com
This is what I think is right, but hoping someone can verify these are in fact Satin Graphite part numbers:
Front: GM Part # 84319210
Rear: GM Part # 84319214
(I think 84319209 and 84319213 are the base chrome front and rear, respectively)
Thanks!
Your numbers match my notes from last Fall when I was trying to order some. Unless they changed since then, they should all be correct, polished and satin.
Thanks!
The cost of these is around $1,000 per wheel.
Have you checked out the Apex wheels? They look great.
Do the Apex wheels have the same width and offset? If not, then the suspension geometry is being affected.
Width yes, offset not exact but close. They typically recommend 3mm spacers on the fronts.
See this fitment guide they put together.
FYI, if you order those GM part numbers I believe you'll also need to order center caps and TPMS sensors as well. Ask the parts guy to confirm if you order them.
And the TPMS nuts ($5 ea, 84413358 for TPMS 84977020, paid $132 for 4) . There could be third party alternatives to the TPMS others have mentioned.
Does anyone happen to know the weight of one of the satin graphite wheels? Front wheels to be specific.
Would there be a reason for a .2 lb discrepancy between wheels, and if so, what would the effect be?
Rear wheels should be wider by a half inch I think
Right. The rears are wider. I'm wondering why the front wheel that discount tire replaced because of the damage they inflicted is 25 lbs, not 25.2 lbs. Idk if the 3 or 4 ounces difference is going to affect anything.
I've got two brand new front polished wheels I was going to use for winter tires but ended up with Apex for Summers when the rears went on constraint. The 25.2 is my measurement because I wanted to compare the Apex VS-5RS (17.9 front, 18.2 rear, same as OEM widths).
