LF Audio
The mods you list are cam (I assume a 32 or 38% fuel lobe), port injection, and E85. Did you do any mods to the low-side fuel pump?
- Cordes cold air intake
- Custom Cam Motion cam kit (includes Cam, Springs, Pushrods)
- DOD delete
- Gm ls7 lifters, Lifter trays, Lt4 head gaskets, Arp head studs, Front main seal, Arp crank bolt, New water pump gaskets, Cam retainer plate with bolts Cam bolt, Amp lock out
- LME head porting
- Kong X-Port on stock supercharger
- NGK Spark Plugs
- Nick Williams 103 Throttle Body
- Gates belt
- OMS Aux pump Kit / Aem 400 Xrp lines and fittings
- Kooks headers w green cats
- DSX lower pulley
- LME Billet VVT front cover
- Reflex fuel controller
- TooHighPSI port injector plates w Fic 1000cc injectors
- Flex fuel sensor
- LMP heat exchanger
- LMP expansion tank
- Supercharger silencing plate delete
Currently running E85 full time
