Slow leak, guidance on how to proceed
oldskoolboarder
Bay Area, CA
2025 CT4V BW MT
2025 CT4V BW MT, stock. My left rear tire continues to have a slow leak. Fortunately, my Miata has a pump so I can fill it from time to time. Clearly something going on. I've never had a car w/ run flats, is this a fixable thing or do I need a new tire?
As long as the hole is not close to the sidewalk then any tire shop can fix it. Recommend patch and plug for best results. Note you are not supposed to track on a patched tire.
Set an appointment with discount tire online, or you can also look into visiting additional local and reputable tire shop options.
Good luck and hope it all works out for you. Happens with the best of us.
