Reverse tilt mirrors quirk
Per4mer08
Phoenix
I’ve only had the car about a week, still in break in period but I’ve come across a quirk that I’m wondering if anyone else has seen.
I set my mirrors to tilt down in reverse, and this part works great. But about half the time after placing the vehicle back into D the mirrors don’t revert back to normal position and I have to manually raise them again. Has anyone had this happen?
One other thing, for passive door unlocking is the car supposed to still have you hit the handle button? I’m used to a Beemer where if fob is close the doors unlock and I can just open them, but this appears to still require the button to be pressed.
I just walk up and pull the handle to open my door. (Holding the inside "Button" for a second or 2) I think I set mine to open all the doors when I perform the above action, so my Passengers can access the vehicle.
This happens to me sometimes, I realized it's speed-related. If you drive away too quickly, the car stops automatically raising the mirrors beyond a certain speed (somewhere around 10mph). It lets you manually adjust them at higher speeds though, and they raise correctly if you pull away more slowly.
