I bet Fernando Alonso is the only current F1 driver that could heel-n-toe in a race if he had to
For a look at some awe-inspiring footwork, search for a video of Ayrton Senna hustling an NSX around Suzuka or Mark Skaife in-race Aussie V8 Supercar footage. I remember one time the commentators shutting up for a couple of laps while we watched (and heard) Skaife speed-shift, power-shift, and flat-shift, depending on the gear selection and situation. He also did brake-checks at the end of the long straights! Lap after lap. Like a virtuoso.
…and in loafers no less!Im going to have to say Hamilton too, he drove Ayrton’s MP4/5B with the H-pattern in it a couple years ago and it was a goosebump moment for sure!
Whenever I’m feeling good about my foot work I go and watch the mentioned BIGFOOT video of Senna and it brings me back down to earth![]()
That does seem weird. You’d think it would blip based on gear selection as the clutch pedal is coming up. Otherwise, how would it know what to match revs to?the blip it gives you when you just push the clutch in and are not downshifting.
Interesting, that’s an angle I didn’t think of.
I haven’t come close to money shifting my BW or their’s at Spring Mountain.
I did a money shift once at the track on a 997 Turbo that I owned, so If I was doing track work with my 5BW I might be inclined to put on rev match simply for that little bit of insurance.
On the street, I’ll keep blipping and heel and toeing! So much fun.
I have rev match in another manual car (Porsche) but never use it as it just isn’t as smooth to me…in the caddy it is so smooth and there is something about the ease of it and the exhaust bark sound that makes me use it all the time. It is honestly not as good an experience in the Porsche so I just rev match myself and it is satisfying in that car (and similarly also satisfying in Blackwing to rev match myself but I choose to let the auto rev match do it).
I can’t understand the point of auto rev match to begin with.
Heel and toe isn’t exactly the same thing as rev matching.I'm okay, but not seamless with heel toe. Also my size 13 is large.
Rev Match makes me feel like a track day hero.
It's a crutch, I fully admit it.
It isn't as crisp, I agree.Has anyone noticed the manual throttle blip (analog rev match with my fat foots) seems sort of "muddy" versus the auto system? Sounds a bit like there is a flat spot front the old carb days (not enough squirter...make your own jokes here). I feel like I'm interrupting some decel process when I try to do it manually because it's not as crisp and lively.
Have you guys looked into these? You could just try the controller first. Seems they have lots of satisfied customers:This is what i keep complaining about. In all engine modes, the computer only allows the actual throttle to move a tiny fraction of what your foot told it to do.
Its even more infuriating when the rev-match shows you how glorious it should be, yet you can't have it.
That's exactly why its so difficult to manually rev-match - the throttle response is so slow, it just doesn't work.
When I first got my Harley, it was so bad it was nearly unrideable. Unlike GM, HD is more than happy to sell you a tuning kit so you can fix it yourself. The throttle mapping table showed that even at WOT you would get only 12% actual throttle when under 2,000 RPM.
Once I flashed it to 100% at any RPM, things went back to how they're supposed to be and manually rev-matching worked magically, as expected.
I very much look forward to being able to do that in my BW.
I kept my carb'ed Harley because of this. Now my CVO 110 with a tune is/was similar prior to said tune.This is what i keep complaining about. In all engine modes, the computer only allows the actual throttle to move a tiny fraction of what your foot told it to do.
I installed these, which greatly improved off-idle throttle response, and mildly improved rev matching.Have you guys looked into these? You could just try the controller first. Seems they have lots of satisfied customers:
SE8223-92, 92MM BILLET THROTTLE BODY FOR (LT1 / LT2 / LT4 / L86 / L87 / L96) — Soler Performance LLC
92MM Premium Billet Modified, Ported, and Calibrated Throttle Body. True 92MM Inlet to 92MM Outlet (through bore). No Adapters Needed. Fits (6.2L Engines) DIRECT BOLT-ON: Corvette 7 & 8, Stingray/Z51/GS/E-Ray (2014-2026) [ C7 - LT1, C8 - LT2 Engine] Corvette 7, Z06 (2015www.solerengineering.com
SE0525-TC DLX Bluetooth® Throttle Controller: Corvette 7/8, Camaro 6, Cadillac CTS 3 & MORE — Soler Performance LLC
The most advanced, wide-spectrum, compact, and durable throttle controller in the market.www.solerengineering.com
