OTA updates?
PeteK
California
2012 CTS-V Wagon, 2026 CT5-V Blackwing
My 2026 CT5-V BW was delivered in April of this year, and I haven't yet seen an OTA update notification. I'm also still on Android 12. I know some folks have said they've never actually gotten an OTA notification for whatever reason, and I wanted to ask if I should wait longer to see, or go to try to talk a dealer into (apparently begrudgingly, depending on the dealer) doing an update.
Thoughts?
Your cadillac app will tell you if a ota update is available also
Yep, but same issue here. It's never indicated an update. I'm just trying to see if others have gotten updates in the last 5 months.
If you are on version 12, then go to the dealer and have the, update to 14. Also have them check for updates for the PDR and other modules as well.
Ugh. Yeah, Just trying to make sure I can make a case for it since VWP is apparently no longer covered by GM without a reason.
I have had the dealer update twice for me. Both under warranty. Tell them OTA update is failing.
This worked perfectly. Thanks! Now any ideas why I wouldn't get the OTA indication? Should I just wait and see? I still no longer see the '5G signal' status indicator on the display fwiw.
Exactly what worked perfectly? Did you end up going to the dealer? I also picked up mine in early April and have not had a OTA update on my car or phone but maybe it has happened without my knowledge? How can I tell if it is updated? Does something on the dash appear different? TIA.
By 'Worked Perfectly' I meant they performed the update without any questions and I'm not on what I believe to be the latest version (Android 14 and the Recorder). When I checked for updates this morning, it did show a .mnf(?) file updated yesterday which I don't recall seeing immediately after the dealer flash, so I'm hopeful that OTA updates may be working now.
