Ct4 v Blackwing air filter install
I am a new member to the Green filter club thanks to my buddy who bought them for me as a birthday present. Those Phillips screws are more difficult to use than the Torx screws on the Camaro. I saw a thread somewhere with the info for the proper Torx screws on Amazon. I’ll order those before I open the air box again. And don’t drop the screw. It’s not fun finding it under the motor.
That may have been me
I ordered both types but ultimately opted for the OEM Phillips head screws
The Camaro airbox screws were identical in every way, but like 25% shorter in length. As much of a pain as it is, i would stick with the OEM ones and replace them when you strip them
Except the OEM ones retail for ~$18 a piece! I found aftermarket ones on Amazon for ~$1 a piece that I posted about somewhere on here.
I'm very interested in these filters and the throttle body upgrade (and bigger Turbos, downpipes, exhaust, carbon fiber driveshaft, tune and all the rest)....but at this time I don't want codes, emissions issues or anything that a dealer may use to deny warranty....etc
So would the green filters (and throttle body upgrade) be recommended and am I inviting any issues?
In my experience WONT
That's kind of where I'm at. On my other 3 turbo cars, oiled air filters are an issue with MAF sensors. This creates a CEL on those 3 cars and its extremely hard to diagnose. Now that we know on our forums, the minute someone gets a code related to boost, we ask if theyre using an oiled air filter. If they tell us they are, we tell them to replace the MAF nad get rid of the oiled fulter. But, WONT TAP said there aren't any issues.
In my experience WONT TAP will not steer you wrong. I have like many done the green filters (oiled) and no issues or CEL's don't know about the throttle body but would be interested to find out.
Just replaced my air filter. Not going to lie…it was a big pain in the ass!
As mentioned before, don’t take the screws out completely. Don’t forget that there is a screw in the middle. You will have to cut the ‘zip tie’ that holds the electrical sensor harness+ disconnect both sensors to get access to 2 screws.
Yeah, changed mine today and my word this was quite a bit of effort for an air filter change. I removed that front plastic piece in front of the air box so i could just loosen the ridiculous number of phillips head screws, lift the lid a bit and slide in the new filters.
In my experience with oiled filters, those codes usually pop up when the filters have been over-oiled. I've seen people just SOAK them and then the obvious happens.
Reviving this thread: Anyone report measurable differences with these filters? WONT TAP: any feedback? Some sources say the better airflow actually has the ECU reducing net output, but this doesn't smell right...
The Green air filters are higher quality and flow better than stock. However, they do not change the power output of the car. We have sold hundreds of these and have never heard of an issue. You can see all the details here:
Green High Performance Air Filters - CT4-V Blackwing, CT5, CT5-V (Pair) - Tapout Tuning
A bit of help here before I force anything. The sensor connectors appear to be held on by a small red tab. It is pushed in initially. However pulling it out doesn't allow the sensor to be easily removed. Before I put a screwdriver or cheater on it to loosen it I want to make sure pulling the red tab to the outside is all you need to do to disconnect it. Once that tab is pulled just pressure to the outside should disconnect it. I am 80 now and bending over getting at those 13 screws is a bit tough on an old man's back.
Edit: Next time I am paying the stealership their $300 for this job. Yes the red tabs release the maf sensor harness but it takes a bit of prying to work them lose.
My experience, you slide out the red tab as you described. Then, push down on the plastic area the red tab was covering and the sensor should pull out with only a little force.
Thank you. I opted for the lot of force option and they both came lose with persuasion from a suitable pry bar.
Hi all! Can someone confirm if this is the right part if not going the hi-perf green route? The configurator says it fits the car but want to confirm. Obviously need two - got that. :) cheers!
That's it.
If not going performance route, I'd ACDelco or Wix.
This one looks just like the Wix, and I wouldn't be surprised if it's the same.
What a hateful task that was to replace the engine air filters. My garage was 90 degrees so it was the opposite of comfortable. The worst part was when I broke on of the little tabs with a hole on the airbox that the MAF sensor wire secures into with a push clip. I'm attempting to superglue it back together...
I hope whoever designed that at GM got put on janitorial duty.
Need to have a bag of new air box screws when replacing filters. These garbage screws are single use as half of them strip out the Phillips head.
Don't even think about going to the dealer for these unless you're immune to severe sticker shock. I found them by the gross for what they're worth.
I had no issues with the screws stripping, I also used a 1/4 impact. I just recall stripping one out when I was re-assembling it.
It's a pain to remove all the way, it's so large. It could have been two smaller pieces and much easier to service.
If you search Amazon for GM 13384034 (air box screw part #), you can find some packages of screws that are not expensive.
