Greetings all! Pulled into a parking lot the other day and did a U-turn to park in a corner by myself. on full lock to lock turn heard/felt a pop and then pedal went pretty much to floor.
She then said brake failure, max speed 43mph blah blah blah.
Took it in and after a bunch of bleeding and testing and stuff multiple times, they had to call GM TAC and ultimately replace master cylinder, brake boost, and ecm with programming, etc.
All appears to be back to normal, but just wanted to get some feedback on two things:
1.) master cylinder failure seems odd to me as car is only 2 years old with just a tad under 24K mi. Anyone else have this happen?
2.) The notes say that when they called TAC, the TAC guy said "a lot of cases, none closed". Ultimately recommended to replace master cylinder which obviously worked.
I know stuff happens, but I'm concerned most about #2. I really don't want to be driving around a high performance car worrying about the brakes going out since there are "a lot of cases, none closed."
Other than that, my gurl has been wonderful....!!
Appreciate any thoughts/feedback
), the pedal felt like it went to the floor to me. I was with an Attorney (mental note: could be good or bad situation there) and she said "just restart the car and maybe that will fix it". Funny, because I run IT for our company so I said "This isn't a computer! but I will oblige since I'm impressed you have listened to our sage IT advice to fix your computer when you screw it up!" Before I restarted the car it said "brake system failure, max speed 62mph", when it came back on it said "brake system failure, max speed 43mph". So we both agreed it appeared to be a leak. We checked and no leak anywhere. After lunch, turned car back on and same message, still no leak. I didn't attempt to drive the car and had it towed to the dealer which is funny because my attorney pal said to just limp it in!
