Adding boost/power....colder plug?
old motorhead
Bellville, TX
2026 CT5-V Blackwing
Looks like I will be adding 3+psi to my LT4. 2.3" blower pulley. Would you change to a colder spark plug? I think the stock plug for the C7 ZR1 Corvette is one step colder than my stock plugs. Probably going to use the ZR1 plugs if I change them. Additions:
Kooks catless 2" headers going to stock mufflers
Bigger heat exchanger
180* thermostat
2.3" Blower pulley
91mm throttle body
Your thoughts appreciated
I am running Kong X Port, 103mm TB, Rotofab intake, ethanol, etc on my Z06 and am running one step colder plugs if that helps.
How much power are you making at what boost? I went from TR6IX's to TR7IX's on my last TVS2300 blown LS3. That one made 660+wheel on 9.5psi. I thought the 7's made the Vette feel sluggish out of boost. I was "advised" to use the 7's to be safe. Ended up putting the 6's back in and never had a problem. New to the LT platform and don't know what to do.
730 wheel, 13-14psi I believe. I notice no driveablitiy issues on or off boost with the one step colder plugs.
Which plugs are you using?
Question is did you regap the plugs? Typically, you'd need to gap TR7IX to .028 or so. They come pretty wide gap at .046 or so.
Yes, regapped and actually had to gap them down a little more because I was making a little more boost than expected (no headers) and we were seeing a little knock.
