Absolute Dearth of All-Season Tires for CT5-V Blackwing
I had the Goodyear F1 All Season on my V1 back in 2007 or so. They were good until they wore down then got really noisy. I would imagine they have improved a lot since then seeing as the competing Pilot was the A/S back then and is now up to A/S4.
Those F1s also seem to be coming in 285/35r19 and 315/30r19 if a little extra width is desired.
Well, dealer called and said the rear Bridgestones are on backorder with no date for shipping, so false alarm...Bummer..
You have to buy these tires in September/early October at the latest or they all disappear with everyone else rushing to get them before it gets cold in the northeast.
Going with the Michelin Pilot sport a/s 275f 285r
Double check that the 285s will fit on those 11” wide rear wheels. They barely stretch out in some cases and can also knock your Speedo off by 3-4 mph depending on OD which result in the car showing more mileage on the odometer then the car actually has on it.
These fit on mine.
I'm running 285/30R19 on the rear as well. There is a little more lip on the wheel then I like to see but it works...and of course the speedometer inaccuracy drives me NUTS.
How much is it off by?
Depends on the speed, but according to the Waze Speedometer I see in Carplay compared to the CT5's speedo:
Under 55 - 1-2mph
55-70 - 2-3mph
70-80+ - 3-4mph
When you run the calculations using these online calculators, the difference should be 1mph, 2mph max with rounding. However, I'm assuming the way OE's have the cars calculate speed based on the speed sensors does not assume 100% tire tread life and thus the reason why the gap is even more than what is calculated.
Example one here - Tire Size Comparison
Ideally, 295/30-19R's would be much closer but I can't find them anywhere. It looks like Pirelli sold them as Sottozero's that GM used to send their press cars out with in previous years but they seem to be discontinued and no longer manufactured as of 2025.
For dedicated setups, are most people running a square setup with 275/35R19 tires on 19x9 wheels with an offset? That is what tire rack is recommending.
Had to jump to 20s to get anything close to usable, but pretty pleased with the results: VIDEO OF SETUP
TIRES
F: 285/30-20 - Michelin PS AS4
R: 305/30-20 - Michelin PS AS4
WHEELS
F: 20x9+15 - BC Forged EH309
R: 20x10+48- BC Forged EH309
The only thing I'd do differently is get 9.5" width rims in front instead of 9". There is a little too much pinch, which lowers sidewall height just a smidge.
If someone wants these front wheels I'll sell them for $1500 (my cost = $1900) just so I can order again and get them perfect. Otherwise, it's really minor and I don't really care that much.
I bought the following from Tire Rack intending to use them as all-seasons on my 5BW. Never fitted them, still have the stickers on. Giving them away free to good home in Northern California if you want to pick them up! (Napa area)
2x 275/35R-19 COOPER ZEON RS3-G1 XL
2x 305/30R-19 COOPER ZEON RS3-G1 XL
Ayyyye… I’ll swoop those if you still have em. I’ve got to come down and visit my house in Vallejo at some point, this gives me one more reason to do that sooner than later. I can PM you with my info.
I was checking Tire Rack for updated fitments for a winter setup over CCBs for my 2022 5BW and it turns out they never scanned that configuration. When I logged into the site I received a notification to update my info to std brakes, they had no option for CCBs for MY22. I had originally ordered the square OZs with 275/35/19s all around. They are only listing the 2026 MY now with CCBs and they are asking us to call for fitment. I am a bit concerned that the original square setup with OZs was not the right fitment with CCBs ....I mean they fit but the rears barely clear the calipers. Anyone else here with the square OZ 19x9 setup for winters with CCBs?
I was checking Tire Rack for updated fitments for a winter setup over CCBs for my 2022 5BW and it turns out they never scanned that configuration. When I logged into the site I received a notification to update my info to std brakes, they had no option for CCBs for MY22. I had originally ordered the square OZs with 275/35/19s all around. They are only listing the 2026 MY now with CCBs and they are asking us to call for fitment. I am a bit concerned that the original square setup with OZs was not the right fit rnt with CCBs ....I mean they fit but the rears barely clear the calipers. Anyone else here with the square OZ 19x9 setup for winters with CCBs?
I’m not on that fitment but now Michelin makes sizes that fit on oem wheels in the Pilot Alpin Pa4s.
My new to me 350 has Michelin Alpine all around at 295/35 19 and they’ve worked nicely in cold temps and slush. On Saturday I did get them to break traction when I gunned it to do a merge. Rear wheels spun a bit then caught traction.
