6.7
So tell me again in that Ai written article where it states that there was NO MORE power that could be had from the LS1 engine without improved cooling capacity. I'll wait. And when did we start using Ai article as 100% factual?
This is the exact reason why more performance shops and tuners don't post in these forums. They don't have time to waste on people like you that theorize about what they know rather than performance shops with real world experience. Most of these performance shops build these cars for people increasing HP significantly for drag racing and road course racing without upgrading the engine cooling. Why is that? Because typically the OEM engine cooling is WAY over engineered for the worst of the worst environments over extremely long periods of time. Your article states that GM targeted 150K miles, most owners aren't keeping their cars that long before rebuilding or replacing OEM worn components so is it really relevant to 99% of people? Go ahead and tell me you're one of those guys that keeps your cars for 18 years and 400k miles, I fully expect it at this point. If that's the case though, you wouldn't be on a Cadillac V forum, you would be in the Toyota or Honda forums talking about how to get more longevity out of your 128hp 4 cyl engine.
I've had numerous cars built by top performance shops, and without exception, they built these cars with significant HP increases, no reliability loss for the multiple years that I owned them backed by multiple oil sample analysis (which I still have if you want to see them), and none of them needed any cooling upgrades other than the supercharger intercooling loop due to the increased boost. The engine cooling was MORE than sufficient for these power levels and these performance shops build upwards of a 200 cars per year for customers, if engines were failing or overheating due to insufficient cooling then they would have added additional engine cooling but you just don't see that in the majority of these builds. Some shops will install a lower temp thermostat and colder plugs but that's typically the extent of it.
The point here is that manufacturers are really just trying to get your car through the warranty period. People that drag race and road race really test the limits of a cars stock cooling potential. Many cars are up to it and some are not. The 2015-2016 C7 Z06 had cooling issues when it was released, not under normal driving but it did when it was tracked on a road course. GM made a very small correction in 2017 to the cooling system and did so without needed to change the aesthetics of the car at all. This was an example of a car that wasn't tested as properly as it should have been. The cars that I owned that I posted previously have all had factory cooling systems that were well designed with lots of additional capacity to increase power without any overheating issues. There are LOTS of ZL1s and Blackwings that get tracked regularly and they aren't overheating, even with power mods. I come back to the C8 ZR1 again, if they can cool a 1064hp car like that without resorting to extreme measures, there will be no issues cooling an 800hp Blackwing if GM were to build it. I drive one every day.
So many silly things in this post I’m done🤣🤣🤣 The admins should put a badge next to your avatar to let people know you dispute science with anecdotes🤣🤣 sorry @jvp
You are, though. Your insistence that the stock cooling on a 5BW can easily handle the 800HP without changes is just that: ignorance. It's based on a tuner doing it, or you doing it. It has nothing to do with what an vehicle manufacturer has to concern themselves with when they increase HP. In this case, by 130.
Cooling will actually impact all of the things I listed in my previous post.
Well, its good that only YOUR statement carries weight without anything to back that up. I don't know how many times I have to keep saying it, I'm literally driving a 820hp Blackwing daily which drives 100% like stock until you press the gas pedal to the floor, at which point the only difference is the acceleration. There's no added anything else other than an increase in blower whine because I chose to install an aftermarket lid just for that effect. Do you have a modifed CT5-V Blackwing that you can speak from experience? The only one of your points that carries any weight is durability. I concede that adding more power will cause more engine wear, but that has nothing to do with the cooling capacity discussion that started this.
You dispute real world results with unproven theory so there's that...
Indeed. To your point, GM already had a fully certified 755 HP package at the time the 5BW was being developed—the LT5. They wanted the most powerful engine they could put in, but they couldn’t package it and meet all mandated federal regs, such as, um, forward visibility.
Grebovic said the extra power wouldn’t have made the car any faster anyway, as they were already putting as much meat on the ground as they could warrantee (there’s that pesky word again).
That is likely because the LT5 blower is taller than the 1.7L blower or a Magnuson 2650. The Magnuson 2650 fits just like the stock blower. GM worked with Eaton to design that blower and didn't care that it was taller because they were going to give the ZR1 a cowl hood to clearance it. It was never designed to fit under the hood of a Blackwing.
