18x10 square possible for CT4VBW for track days?
JustAGuy
Maryland
Shopping at the moment
Please pardon if this has been asked before: Has anyone fitted a square setup of 18x10 wheels on a CT4VBW? I know that Apex sells an 18x9.5 setup with different offsets for the front/rear, but I haven't found any references to an 18x10.
Here's my use case...and why I want to run a square setup if possible: I run the One Lap of America event, and the rules allow you to carry 1 spare wheel/tire with you if you're running a square setup, and 2 spares if you're running a staggered setup.
As a driver, I like a square setup. I've been driving track events for 20+ years in a lot of different cars, and I've changed to square setups on several cars that came from the factory staggered. I've had very good luck, including my current Mk5 Supra. Logistically, I don't want to carry 2 wheels/tires, as I have to pack for a week+ in the car, and even in a sedan like the BW, space is a premium.
My desired setup would be stock suspension, 18x10 with 275/35/18 at all corners, aggressive alignment per the owners manual. I'm willing to trim/clearance the fender liners a little, etc. I know this is breeze for the rear, but can it be done in the front without significant modification?
Even if I'm limited to a 9.5" wide front wheel, how does the 275/35 fit?
I'm not sure if this answers your question but there are people running the 19x10/11 OE 5BW wheels on their 4BWs. So a 10" width up front should work. You can find some pictures and threads on this forum.
That does help, and I'm sure there is info in those threads on spacers (if needed) and it should be easy to find the offset for the 5BW wheels.
I have the 18x9.5 and even with 275/35/18 there's TONS of room between the tire and fender edge. There is NOT much room if any between the wheel/tire and the strut. The 6th Gen Camaros have this same issue and in order to run square, they install a 25mm spacer with longer studs. I'd imagine the same could be done with our platform, but whose gonna be the first to give it a try? o.0
I want to run the same setup but, with 19's. With 18's how much room is there at full lock?
Appreciate the feedback. I have no problem running high quality spacers and the right lug studs.
Mount one of your 275/35's on a front wheel and test fit it. If it works then 275/35-18 can be your square setup.
If they are too tall, I know 275/30-18's will fit mounted on 18x10 wheels, so that could be your square.
You could also go 285/30-18 square or even 295/30-18 square on 10" wheels.
I'm going to do 285/30's on 10's and 295/30's on 11's.
While you can run a square setup with the same size tires and wheels, the wheels are not interchangeable front to rear. The offsets on the wheels are drastically different.
In a different life (crummy old Porsches), we managed the differing offset needs with spacers. I know using spacers on track can be a bit of a controversial topic. I've had good luck with quality hubcentric spacers, ARP lug studs, and proper lugnuts for the wheel.
I suppose a front wheel could be used on the back with a larger spacer. However, the studs that work for your rear wheels would be waaay to short to be used with the front wheel and a spacer. Lugs long enough to use with the front wheel with spacer would be waaay to long to work with the rear wheel.
In my case the offset difference is 30mm.
