phdibart
I have a '23 4BW with the 6M. It's my understanding that these Tremec TR6060 transmissions are known for notchy 1-2 shifts, especially when cold. There's an older post here at ************** about the same shifting issue in an ATS-V.
I've noticed the transmission can also be a little notchy with low speed shifts. When I'm nailing it, there's no notchiness at all, but driving around town in traffic it can be a little bit.
Do you all have similar shifting in your BWs? Has anyone tried a different fluid like Redline D4 ATF, which is Dexron III rated? Or Tremec's HP-MTF? If so, which fluid and did it improve shifting? Will using a non-GM Dexron III fluid void the powertrain warranty?
