1Evil55
That's how I do it except I will let it run without power for a few minutes and it is still an issue. I think some of it has to do with where the in supply to house comes from versus where it goes to(opposite side of house) along with the fact we have more bathrooms than people in the house and they never get used. Of course I could be way off and it is just simply because of a POS machine.Hm, that's weird. The only place there would be air, is within your pressure washer. You're supposed to basically prime it by leaving it off, hooking up your garden hose to it, turning on the water until you see a steady stream of water coming out of the pressure gun, which takes about 20 secs to clear out the air. Remove the angled head so you can get the full stream of water. Once that's complete, then you turn on the pressure washer. At that point, it's ready to go. Are you doing this step or is it something else?
