blkout
Better cooling.Why would you need to remove the rain tray ?
If you remove the tray, water will run off right on top of the accessory belt. Since I have a JLT intake, it would also partially run right on top of the air filter too. It's certainly something you probably wouldn't leave off all the time if you ever drive in the rain or when you wash the car. I'm sure its designed to be removed for track use.If you remove the tray, then does water go right on top of the engine during washing or rain ? Does the tray have a channel for water to runoff, in a good spot in the engine bay ?
What size clamping screws does the carbon fiber hood use? Just in case I need to order them. Thanks.The heat shield is required to be installed for warranty purposes and honestly, it works VERY well. I left my carbon fiber exposed on the underside although it's nothing special to look at. I don't love the silver bolts used to hold the rain tray so I replaced mine with these, makes for quicker removal too.
For the rain tray? M5 x 20mmWhat size clamping screws does the carbon fiber hood use? Just in case I need to order them. Thanks.
I did the same, left the carbon fiber vents exposed. I waited 6 weeks before getting some mild paint correction done and then PPF on the hood.The work has started and my brother says the fitment was very good. Now some paint and clear coat. I am only leaving the vents as carbon fiber. Then after a few weeks of paint curing, I will get the PPF done on the hood.
