Wheels for CT5 V Blackwing
Ryana1992
North Carolina
2025 CT5 V Blackwing
Does anyone know where I can find rims like these? I see Apex offers them but I'm looking for a more aggressive offset. Below are the specs I'm thinking, looking for full forged. Also open to other recommendations based on what you all are running, looking to put them on a radiant red color blackwing.
19x10 ET20
19x11.5 ET48
I've done a pretty exhaustive search in the past and I think you might have to go with custom wheels to get the desired sizes and offsets. I couldn't find much in the way of off-the-shelf wheels other than Apex and maybe Vossen or Velgen I get them confused.
This has been discussed a few times before. Because of the big brakes and large offsets makes it difficult to achieve the deep dish style it sounds like the OP is after.
Would a 19x10.5 ET20 fit in the front on stock height with no rubbing or issues?
It should. But if for some reason the wheel touches the strut, loosen the strut bolts and pull the knuckle out to take the camber out and give you more clearance.
that will fit with 285/35's?
It should, im running 285/30-20s on a 20x10.5 +13 wheel. The overall diameter difference is minimal, with yours only being .5% taller.
