CT5-V Infinity sound app
nordique14
WA
5BW MT V8V
FYI, installing the Infinity Personalized Sound app on my 2025 CT5 works (I assume it will also work for 2026). It gives you full equalizer control and also has a test where it will determine a personalized EQ setting for you by playing sounds. You do need to grant the app permission to adjust the audio settings but the app will prompt you to do that once you have finished the sound test.
Interesting. Contrary to a lot of opinions, I think the sound system in the 4BW sounds great, especially after adding a sub. I’ll look forward to testing this out.
It looks like this is only for Google built in systems. Only for 25+ 5BW.
I can't get passed this screen
I had the same issue. I am not sure if it was me fiddling around with something or if it just took some time, but it eventually went into the setup mode with the test tones.
I was able to get it to work. Used the long press of the start button to put the car on but engine off. Then opened the app. After I couldn’t figure out how to get the test to start, I hit the car start button again and that somehow caused the app to trigger the ability to start the test procedure.
Even if someone doesn’t like the results and setup from the test, we now have a 10 band eq!
My phone says the app is not compatible with my Samsung Galaxy s25 ultra
It is not a phone app. It will not work via CarPlay or Android Auto mirroring. You have to download to the infotainment unit directly. Which means only 2025-26 CT5.
Yeah i was definitely trying the app without the engine on. I'll try this when i get home next weekend.
  • Like
Reactions: Z28
Does anyone know if utilizing this app screws with the active noise cancellation at all? Or is that still active?
So yep, wouldn't work with engine on, once pressing the start button to shut down, it prompts to calibrate.
  • Like
Reactions: Z28
Did it make a noticeable difference in the AKG system for anyone here? It seems the system lacks with its ability to generate bass.
I get decent bass. Still testing the sound app vs normal eq. For Spotify i did have to set it to highest quality streaming to get any decent sound.
Seems that whenever Carplay is active it defaults to the non-eq settings?
At least that's what the persistent warnings said that I kept getting (before I muted them in the google app settings).
For me it’s a really clear improvement as it allows to shave off some of the highs in a way the stock EQ can’t. It’s a more enjoyable listening experience with it for sure.
What I have noticed that is somewhat annoying is that I need to go in and activate the app each key cycle to ensure it’s working. Not a big deal but occasionally forget and notice when things sound flat again.
I have a '25 5BW. I don't find the app when I search in the car with the playstore app. I see it from a browser on a laptop (INFINITI Personalized Sound) but when I click on install it it lists "Gm Cadillac" but says it's not compatible and won't let me install it..
I think my car has the August 2025 update.
GM or Nissan may have caught on and requested that GM cars be removed from the compatible device list on the play store.
