Absolute Dearth of All-Season Tires for CT5-V Blackwing
I thought the BW came with ZP tires. Is this not correct?
Also, my understanding is that the spec BW tire just has a little bit of foam in it, which makes it a little more quiet than a regular PS4S. Big whoop. No performance advantage.
That is not correct.
Unsure of the foam. Sure of the hybrid compound.
Couple photos of TPC code on my 2024 5BW OEM tires PS4S. (ok yep..no run flats).
That front 275 says "acoustic" (whuts that? foam?), didn't see acoustic on rears. I'll look again, want to see what my DOT codes are..for the log book.
ooops, time to scrub and dress these!
2024 @ 485 miles.
275 TPC3162, 305 TPC3163
In the same boat here - really need to locate all weather tires. Where are you GM/Cadillac?
The reason I say that is, I've been running all seasons for the past 5 years. Prior to living in the high desert, I lived in Southern California for 30 years, and before that, Michigan.
In my experience, all-seasons work for their intended purpose, but there is a significant sacrifice - in EVERY season - mainly traction, whenever you actually need it.
I have run what are considered to be the top two "Ultra-High Peformance All-Season" tires out there - the Contis and the Michelins. Both exhibit this characteristic.
I'm not saying DON'T run all-seasons. I mean, I do right now. But for a performance sedan, they pretty much suck, because I have to drive at the limits of the tire - I can't drive at the limits of the car.
The car I have now (my BW goes into production this week or next) is a RWD sedan powered by an LS3 (415 HP/415 TQ) through a 6-speed auto. It is relatively mild compared to a BW.
It is disappointing enough having to drive this car at the limits of its tires... there is absolutely no way I am going to do the same thing in a Blackwing. May as well just save $100K and stick with what I have.
When my BW comes in I am going to rip off the stock run-flats and get PS4S in 275/325 for the summer. Then a set of performance winters (or perhaps all-seasons) on different wheels for when it gets cold.
All fine and good but needing something that can get me through my winter requirements along with being able to roadtrip out west to where it gets well above safe temps on winter, I have a requirement that I can't get around. At this rate I'll end up with a second set of wheels/tires for summer, but all seasons are my requirement that I need for winter.
So we're back to the original part of what are the best options to do for running all seasons on this car?
If you've read the post, you know they don't make any.
If you've read the post, you pretty much know the options.
If you've read the post, you know I am the OP. So I get it.
Sorry there's not a better answer.
"RWD sedan powered by an LS3 (415 HP/415 TQ) through a 6-speed auto". Chevy SS? My 2016 was totaled a few months ago. Great car. RIP.
I am going to jump in here to rile up a bunch of people.
I we two CT5 Blackwing's a 24 and a 26 because we like them.
I don't care about performance but I wanted a V8 in a Cadillac sedan
and I like the look.
The only thing that seemed out of place is the fact that the front tires are larger in diameter than the rear. And I drive all year around.
That is what I bought the cars for.
I found the solution to both issues is 275-35 19 front and 285-35 19 rear.
100%. According to Tire Rack, there are 7 brands with all seasons in this size combination. I went with the Continental Extremecontact DWS 06 Plus and have been pleased with them for colder weather. I still prefer the original equipment tires for summertime though. I had a 2019 GT350 and it had the exact same size rear tire as the BW. I used 285/35 all seasons without a problem for that car. Rinse and repeat for the Blackwing.
The stock size rears are not available for any all season tire! Fronts yes, rears no. If you must have OEM sizes, then you will not have All Seasons. Your choice then is to either park the car for the winter or pick a different car. That's the reality. If you want to drive the car in cold weather, you have to be flexible. 285/35 is the best approximation I could find. I've driven 285/35 all seasons instead of 305/30 summer tires for 6 winters. Nothing blew up, no warranties voided, no problems. Your priorities may be different, but I prefer to be flexible and enjoy an amazing car 12 months of the year.
Ah, I went back to the beginning. It seems to me you are not really interested in finding a workaround, but maybe I am misunderstanding your comments. Yes, GM has not provided a one for one all season solution. It turns out Ford didn't either for a car I previously owned. We can either nurse our grievances or try to find ways to move forward. I prefer to find work arounds and move forward.
I don't think it is appropriate for you to suggest that I am under the influence. We should try to find more respectful ways to disagree.
Arguing behind your keyboards. Give it a rest!
