weird idles
1Evil55
here
81-0205 & 56-8012
I recall some folks having issue with RPM's jumping without input from the driver. I've noticed my BW4 do this many times, almost always when parking. I've tried explaining it to the dealer when I'm in but they can never reproduce it. I am of the belief the problem is in the automatic idle our cars have as we begin to let the clutch out. More often than not when I'm parallel parking my last direction is reverse into the spot. Usually it is a very slow speed and I'll use the auto idle to maneuver in. Once I get into the spot and stop I will take the car out of reverse and the idles will start acting on their own. I've noticed sometimes the idles increase with the press of the brake pedal. Sometimes I can work the clutch in and out and the RPM's will follow what I'm doing with the clutch. RPM's have never increased by itself when in gear. This video, hopefully it loads, I took just after parking in my garage. I made sure to lift my feet up some from the pedals to be sure nothing was touching. The motor keeps reving up and down on its own. Bueller?
My 4BW does this from time to time as well, also always when parking. I think it is just the anti-stall getting confused.
I wish there was a way to disable the anti-stall option.
I agree, I am not using my BW to teach my son to drive stick because of it. Boy has to learn how to stall like a real man.
I for one am man enough to stall my 4BW, despite the sophisticated anti-stall controls.
It's happened to us all.
sorry top gear GIF
Wow, mine has never been that bad...at most one 2k rpm blip without touching the gas.
I'm guessing that whatever sensor the car is using to tell if it needs to blip is going bad. Do you have any other driveability issues?
None. This only happens when I'm parking, typically reversing in. It always happens when I'm in the downtown area parallel parking and like clock work there is a family next to my spot looking at me like I'm a hipster dipshit trying to flex with revs.
