Corsa Xtreme Exhaust issue
Looked on YouTube. There are sevaral videos regarding exhaust installation with valves. Is there something about the video, like type of car, that will help me narrow my search? Thank you.
Thank you to everyone. I sent everything to the second shop, and they said they did everything that was suggested. At a total loss. Thank you for all the assistance. Anybody have a good contact at Corsa who will actually return calls?
Good
Good luck with Corsa, they are not the best in phone calls. Hard to believe there can be that much to it though, should be fixable.
Did you actually remove your inside tips and look down your pipes, as I mentioned, and see if your valves are actuating when drive modes are changed, or are you just taking their word for it?
I have the launch which I bought for my C8 when I installed a Borla ATAK for the exhaust valve relearn instead of taking it to a dealership. The exhaust swap will absolutely throw a code unless you do a relearn, I'm assuming its the same on the Blackwings since its basically the same tech.
Borla gave instructions on how to do the relearn in their instal instructions and it worked great using the Launch scanner. I also recently used the Launch on my C7Z to clear some codes while installing a throttle controller.
If you don't know how to do the valve relearn I would look up the Borla ATAK install PDF for the C8 and it will have them. Easy to download from Borla. You can follow the same process.
I never had an issue after doing the relearn on my C8, CEL never came back after the install.
I was thinking about doing an exhaust system on my 5BW. After reading this thread.....Corsa has lost a customer. I will be researching Borla.
To this point I have just taken the word of the last shop, but just got back in the country yesterday so will do it this weekend. The last shop created a very detailed report which specifically said they viewed the valves working during the switch in drive modes.
Let me know what you find out. I’ll be installing the Corsa next week and want to make sure I can avoid this headache if possible.
Looks like valves are operating properly. Was able to get a hold of Corsa last week. Based on the finding from the third shop, they are shipping one side of the exhaust to see if that cures the problem. If not, they think it is a weak OEM actuator. Corsa said exhaust should ship next week. Will post updates.
Interesting, be sure to report back with results.
Just had mine installed last week and of course getting a CEL. I have my first oil change scheduled for tomorrow and will see if they can do the valve relearn on it. I bought a Launch Creader elite but cant figure out how to do the relearn as of yet although I'm sure if i spent more time on it i could but at least going to ask them tomorrow if they have time since the CEL is on
As an update, all attempts to get the light to stay off have failed. After a couple calls with Corsa, they shipped the driver's side exhaust based on the codes. Taking her to a new shop tomorrow and will provide them with all the paperwork from the previous shops.
Team, I had the issue with the CEL - the trick is to reset it with the exhaust valve relearning procedure. Once that is done, start the car with the valves open (in V mode or so) then it should relearn it properly. It took me a few tries to get it right but finally cracked it. Good luck to all!
Are you still good with the CEL? A couple of the times I would go a couple days before the CEL would come back on. I was not able to take my BW into the shop last Thursday but did drop her off this morning.
Yeah, that trick fixed it. I haven't had issues for several weeks.
Just heard from the fourth shop. Their immediate diagnosis was that the Corsa exhaust "bound up" the actuator. Basically, the spring(s) on the valve on one side is too strong for the actuator. They predicted that replacing the exhaust would not make the codes go away, but since the problem is the exhaust, it had to be replaced. They replaced the exhaust and were right. The codes did not go away. They ordered a new actuator ($170) from Cadillac and are pretty confident this will fix the problem. We will see if they continue to be right.
Did replacing the actuator fix it?
Good question. The short answer is no. I just got her back on Friday after two weeks. I think the shop tried every day for two full weeks while I was out of town. Check engine light is off, but the O2 sensor code has not cleared. Taking her back in tomorrow (Monday) to see if the O2 has enough data. Corsa's response is basically, "your car is rejecting the exhaust." I drove her around Friday evening and yesterday and tried to get an emissions test, but she did not pass. If anyone has any sway with DOGE, please push to have the non-attainment zones, or just the whole EPA, abolished.
After six months, four shops (including a Cadillac dealership), countless trips to those shops, replacing one side of the exhaust, replacing an actuator and $________, the check engine light has now been off for a week, and our BW has passed emissions test. Hats off to Tech One in Cedar Park, Texas. They stayed with it and did not give up. They could have charged me an arm and a leg for the time they spent but only charged a pinkie finger. Fingers crossed it stays off. Nothing special was done after the actuator was replaced. Just kept resetting and putting on mileage. From the replacement of the actuator it took seven or eight resets before this time.
I wonder if it would have been possible without installing the new actuators. When I first put mine on and triggered relearns/cleared several times, it didn't do anything. I ignored the CEL, and then it went away for a few days. Then it came back. I'm glad yours went away, lol. I think new actuators and ignoring it might be the fix for me.
Dropping it off at Cadillac next week for "Service Brakes Worn" spamming my dash when I hit the gas. The car only has 11,600 miles, so I don't need new brakes. We'll see if they mention the exhaust.
